Skip to content
SN 00042 Restoration; The Older Twin
But a conventional rotisserie makes working on the rear of car and the nose of the car really difficult
6 hours ago, motorman7 said:
The inner rear seat mount looks to be in the wrong place to me. You may want to have them double check.
Thanks for the heads up. I will double check the seat mount location next time I am out there. I was thinking it might be the picture angle but won't hurt to check. Thanks!
Edited by motorman7
  • 4 weeks later...
The body shop work continues and looks like things are moving along nicely. I am happy to see that they are being very thorough and even cleaning up areas that no one will ever see.
I did check the seat mount locations. The rear inboard bracket on both the drivers and passengers side is off by about 2 inches (both are too far outboard). Carlos has a welder and will do the re-mounting of the bracket. I did contact Larry, the original metal work guy, to point out the error. Looks like we will get that re-mounted for no additional cost. I also sent pics of the dimesnions from the seat rails. The dimensions that I measure are 13.0" wide (330mm) and 12.75" deep (324mm).
I removed the air galley from the exhaust manifold, but was not able to salvage it. After repeated heating, cooling and lube applications, I was only able to get 2 of the fittings out. By this time, the hex portion of the remaining fittings were starting to get pretty trashed, so I ended up cutting the tubes on the remaining 4. Fortunately, I did not have to do any re-tapping of the four difficult fittings. I was able to drill away most of the metal in the center of the fittings and sort of peel the threads off of the manifold. This made is easy to save the extension tubes that are secured by the fittings.
On all of the previous cars that I have restored, I have always used a gray powder coat finish on the exhaust manifold that Les Cannady at Classic Datsun Motorsports always uses. Since we want to be very exact on the reproduction, I was considering a high temp cast iron paint which would be closer to the original color. However, it was noted that those typically peel even with the best prep and application. POR 15 was recommended, but again, this ends up being a colored paint and softens the texture of the original cast iron and doesn't really replicate the original color. I eventually phoned Rod Schmitt of Rod's Garage (Restorer of the 2025 JCCS Best of Show Red 240Z and John Morton's 1st place Green 240Z in the 240Z category) to find out what he uses for the final finish on the exhaust manifold. Rod says he cleans the manifold well with wire wheel and then uses a couple light coats of graphite spray for the final finish. He says this comes the closest to the original color and finish. It also handles the high temps well. So, this is the current plan for the exhaust manifold finish.
I have started cleaning up some of the steering column parts. Some before and after pics are attached. It looks like these components have been accessed previously as the turn signal mechanism had a wire that was just twisted together with an extension on the horn circuit, so I removed the extension and soldered the wire in place. It has a broken connector which I thought I could replace with another signal mechanism that I have but that replacement was just as brittle as the broken coneector, so I just ordered a new one. Also, the headlight mechanism looks surprisingly good, so I am thinking that may have been replaced as it looks virtually brand new. Typically, these are pretty gummed up and the white parts are yellowed and/or dirty. This one looks untouched.
I will re-restore the steering wheel as the previous restoration is poor. The black paint is thick and uneven and should be a satin finish, not gloss. The 'wood grain' portion has a heavy gloss finish, should be light satin or semi-gloss, and the back side with the 'nubs' was over sanded so the wood grain appearance is missing on the nubs.
For your possible reference, 1970 FSM Figure BF-3 ('Standard body dimensions') gives these as 331mm and 320mm.
My now closed shop generated 4 Gold medallion stock 240 recipients. We tried 2 different finishes for exhaust manifolds. One was a finish like you're using and the others had Jet-Hot cast finishes. In EVERY case the judges (?) said the finish was incorrect and deducted points.
Our last Gold Medallion car was judged (?) to have a steering wheel finish which was "too shiny".
Go figure!!!
Zspert, Care to share your opinion of a closer to “right” color?
Will be traveling this road shortly…
Amazon has a can of graphite heading my way already. I do wonder is there consensus for color of the manifold, that will last a few dozen/hundred heat cycles.
This is the Jet Hot cast finish. Please excuse the slightly green cast which is the result of either lighting or camera user error. I like the color but more importantly it's extremely robust. After more than 25 years the exhaust manifold on my 280 still looks like it was just done. Hope this helps. Not a job one wants to do twice.
PS This is the exhaust manifold from the Z used as the model for the Franklin Mint Z car
Quite the contrast in colors
This is a later manifold testing colors….same material as motorman7 with tubes in place… looks much darker with contrast…IMG_2786.jpeg
Too dark, black really. I looked again of my pix of the Franklin Mint manifold above and the true, not light distorted, color is at the extreme ends.
