Skip to content
New Gold Standard
31 minutes ago, z8987 said:
Engine compartment and wheel well cleaning8f50b0125923246a84ccc8a25f89856b.jpg
What it would look like to get a flat in 1970. I’m using simple green to take off the layers of grime. I used a plastic scraper on the thick stuff on the struts. It takes the paint off. I started using a plastic brush, it works but the thick stuff is a problem, any ideas on a better way to remove the thick grime?
I used plastic paint scrapers. They're cheap so you can get a few sizes. I like Murphy's oil soap. It's  a good cleaner and no harmful chemicals. Mix it with super hot water for the best results. I have a plastic coffee container with a lid and microwave it before using. Sponge it on let it sit for 10 or 15 minutes then scrap the greasy goop off.
Took a short drive out to 8789’s house today to check out his new acquisition since we live in the same town. Awesome looking car! He forgot a pic of the original antenna. [emoji106]
Simple green is pretty benign. if it takes the paint off Purple Power probably will too. Drop back to hot water and Dawn dish soap. You might be able to up it to dishwasher soap which is a little stronger...
15 minutes ago, sfm6s524 said:
Took a short drive out to 8789’s house today to check out his new acquisition since we live in the same town. Awesome looking car! He forgot a pic of the original antenna. emoji106.png
Thanks for the visit. It was nice to hang out and talk cars.
Dang Tapatalk, admin can delete dups if you want. [emoji35]
How do I get a period license plate for my car?
Sent from my iPad using Tapatalk
https://www.dmv.ca.gov/portal/handbook/vehicle-industry-registration-procedures-manual-2/special-plates/year-of-manufacture-yom-license-plates/
You’ll need to hunt around or buy a pair of blue plates, and an old 1970 year sticker. Got my sticker off eBay, plates can be found other places, and may be priced at $200-300 depending on condition. For a 70 I’d try to get a pair that start with a lower number since that was to first year for blue plates.
Once I get them what’s next? Do I register as a specialized plate and put on the blue plates
Rathe than the plates I receive?
From what I read it says 69 or older!  Commercial has 1970! Did I miss something?
