Skip to content
Just Another Damned Z Car Project Thread
16 minutes ago, w3wilkes said:
As opposed to what, the Tacoma ?
Yes. My (all?) Tacomas hunt for torque so they shift up and down. Super annoying. Forces me to have my foot in it a lot.
I have a '22 Frontier Crew Cab that I thought was way too aggressive on it's shifting, especially at freeway speeds using cruise control with plenty of hills and valleys (I-15 from Ogden, UT to St George, UT, about 350 Miles, open road about 225 miles with speed limit 80MPH, the rest is 70MPH). Nissan did a reprogram of the transmission control unit and it's a night and day difference! And I really appreciate that Nissan did a 3.8L V6 N/A engine.
I've driven the 240Z down to St George a couple of times for their Easter car show. I'd really like to find a wide ratio 5 speed. I thought the '78 280z had a 5 speed that 1 through 4 was the same as my 4 speed and the 5th gear was like overdrive.
My '77 has that wide B like you're talking about and I got one out of a '79 2+2 that I put in my '72 and am really happy with it. Never use 5th around here but it's a game changer on the interstate roads.
  • 2 months later...
As long as we’ve brought up our daily drivers, every time I go to the Toyota dealership they were telling how much mine was worth and how I should trade it! I double crossed them and sold it to a private party for $36K and bought this! Holy Schmidt it’s fast for an SUV. Porsche Macan GTS. That’s one of the other three Porsches sticking its tail out of the garage behind it…
  • 1 month later...
Well hell! @Tanker what year was that Honda electrical brake booster? Did you get a hold of the 3D print file? I’m intrigued but I can’t find the Facebook thread! 😫
  • 1 month later...
So, having solved the problem of a bridge between the Bosch DBW throttle body and the native 280Z intake, I need to make gaskets for the bridge. I tried successfully to hand cut gaskets with an exacto knife and a cutting mat using gasket material. It would work, but it isn’t as pretty as the project deserves. So I bought a new in box Cricut Maker 3. This willl cut leather, so gasket material is cake. I need to draw it up and convert it to an SVG file but I will post picks of finished gaskets.
Oh, and this came today. PTunerz thermostat housing. Had to bolt up a Canadian part in honor of my Canuck brothers…
  • 3 weeks later...
Ok, exciting news. Well, exciting for me anyway. It was a steep learning curve, getting a whole lot less than fluent, but sufficient in AutoCAD. I drew up the gaskets necessary to attach the throttle body spacer to the stock 280Z intake manifold. I then converted them to SVG files and printed up the gaskets on plain paper (gasket material is more expensive and I don’t have a lot of it hanging around).
  • Popular Post
Finally, I printed them on the gasket material. Perfect match! Next project is to make a blanking plate for the cold start injector. I’m not going to use that with the Haltech. Cold start enrichment can be programmed in.
They look pretty good don’t they?
Edited by conedodger
I’m pretty golden in 2D in AutoCAD. Pretty sure I’d need help with any 3D design.
