May 3, 20241 yr Author Popular Post comment_664867 Something fun I have been working on! I really want drive by wire on my 240z. But figuring out a location for the actuator has been tough to say the least. I don’t want it hanging over the intake. This is a 100% bolt in adapter featuring a BMW 6 cylinder actuator and a 350z pedal. This will attach to stock linkage and drive my ITBs. Hopefully it works! The pivot arcs a far bit, so that might not work and the pedal mount might flex too much? Time will tell. This would allow me modern cold starts, any sort of progressive pedal movement I could want. Full idle control, traction control, valet mode, cruise control and way easier tuning. We 3D scanned the pedal area and the actuator to mock it all up in CAD! All of this is 5axis cut out of 6061. Link to comment https://www.classiczcars.com/forums/topic/58568-duffys-171-series-1-240z-build/?&page=86#findComment-664867 Share on other sites More sharing options...
May 4, 20241 yr comment_664896 I was very impressed with that same throttle by wire system BMW used on the S54 M engine, I had to reluctantly install it when I couldn't find anyway to delete it from the programming. I couldn't believe the pedal feel would be as good as mechanical linkage but was pleased to be proved wrong. Link to comment https://www.classiczcars.com/forums/topic/58568-duffys-171-series-1-240z-build/?&page=86#findComment-664896 Share on other sites More sharing options...
May 5, 20241 yr Author comment_664953 Well it works. But the firewall flexes too much (1-2mm) IMG_2655.mov   , next I will try to mount to the pedal box which doesn’t flex at all. I also want to keep the arm movement on the same plane. Currently actuator is up and down and bell crank is left to right. Link to comment https://www.classiczcars.com/forums/topic/58568-duffys-171-series-1-240z-build/?&page=86#findComment-664953 Share on other sites More sharing options...
July 2, 2024Jul 2 Author comment_667000 New ITB intake is getting sent off to China to CNC cut! This fixes a few mistakes on the first version and also gives me the stock J-hook pivot as an option. It will feature a bolt on banjo balance bar and ideal injector angles. It's slightly longer then the last version as well. Link to comment https://www.classiczcars.com/forums/topic/58568-duffys-171-series-1-240z-build/?&page=86#findComment-667000 Share on other sites More sharing options...
July 3, 2024Jul 3 Author comment_667031 Here is the length. Link to comment https://www.classiczcars.com/forums/topic/58568-duffys-171-series-1-240z-build/?&page=86#findComment-667031 Share on other sites More sharing options...
August 9, 2024Aug 9 Author comment_668117 Wow is all I can say 464f5f2c-e7c2-4dd9-affb-6d86115b0fea.mp4 Link to comment https://www.classiczcars.com/forums/topic/58568-duffys-171-series-1-240z-build/?&page=86#findComment-668117 Share on other sites More sharing options...
November 6, 2024Nov 6 Author comment_671109 Well drive by linkage is fast and accurate. Pretty darn stoked. I might try a few more actuators. Since the one I picked is being discontinued (BMW S54 13627840537) This should make anyone doing ITBs life much easier. Cold starts, traction, AC, intelligent throttle curves. This is just hooking it straight to a 12v source. So it’s just on or off. Actually when wired to the ecu, closing will be faster. This is returning via springs. When hooked up to the ecu. It’s powered open and closed.   Link to comment https://www.classiczcars.com/forums/topic/58568-duffys-171-series-1-240z-build/?&page=86#findComment-671109 Share on other sites More sharing options...
November 6, 2024Nov 6 Author comment_671110 So fast!  Link to comment https://www.classiczcars.com/forums/topic/58568-duffys-171-series-1-240z-build/?&page=86#findComment-671110 Share on other sites More sharing options...
November 7, 2024Nov 7 Author comment_671139 Dual L6 knock sensors using the stock block m6 hot water pipe mounts. They are actually about perfectly placed!  These are just ti prototype. I am designing my own and will be adding them to the things I make and sell. Link to comment https://www.classiczcars.com/forums/topic/58568-duffys-171-series-1-240z-build/?&page=86#findComment-671139 Share on other sites More sharing options...
November 7, 2024Nov 7 comment_671141 What knock sensors are those Duff? Most of my sensors are BMW. I hadn’t considered knock sensors because I didn’t know where to mount them, but you’re right. That’s pretty much the perfect spot. Link to comment https://www.classiczcars.com/forums/topic/58568-duffys-171-series-1-240z-build/?&page=86#findComment-671141 Share on other sites More sharing options...
November 7, 2024Nov 7 Author comment_671146 5 hours ago, conedodger said: What knock sensors are those Duff? Most of my sensors are BMW. I hadn’t considered knock sensors because I didn’t know where to mount them, but you’re right. That’s pretty much the perfect spot. Bosch off a BMW. I ordered the studs already! They are nice and cheap.  Link to comment https://www.classiczcars.com/forums/topic/58568-duffys-171-series-1-240z-build/?&page=86#findComment-671146 Share on other sites More sharing options...
November 23, 2024Nov 23 Author comment_671707 Custom grade 5 titanium studs of my design. I am so tired of installing the old studs and I hate the look of the allen ones. I designed intake, exhaust, my intake balance banjos, knock sensor stud, stack studs and my intake intake/ throttle studs! The flat spots work perfect with a box wrench. I also love the look of a rounded tip on a stud. I think they came out awesome, after testing I will be selling. I bought enough, that they should be fairly cost effective as well. Edited November 23, 2024Nov 23 by duffymahoney Link to comment https://www.classiczcars.com/forums/topic/58568-duffys-171-series-1-240z-build/?&page=86#findComment-671707 Share on other sites More sharing options...
