March 23, 20169 yr comment_490165 Well I hope I'm not sounding like a know it all either as I'm certainly no carb expert. Heck, I've never even taken the 72 versions apart. Haha! Jarvo, Thanks for the info on the 72 alignment cones. I've held the 72 versions and looked them over casually but they weren't mine, so as much as I wanted to, I couldn't disassemble them. And I'm loony, but if I was mixing and matching parts and had binding pistons, I would heat and dig out the existing nubs, make myself an alignment tool, fixture and lock the chamber into it's new correct position, and epoxy inject myself a new set of nubbies. A little release agent on the chambers before fixturing.... Clearly overkill, and a good example of why why my projects take ten thousand times longer than normal! Link to comment https://www.classiczcars.com/forums/topic/52647-engine-only-runs-with-starter-fluid/?&page=8#findComment-490165 Share on other sites More sharing options...
March 23, 20169 yr comment_490168 I love these SU carbs and have rebuilt many sets over the past couple years. Happy to help out fellow enthusiasts! Its fun turning beat up and worn out examples and refurbishing them. Here are some before & after pics... Link to comment https://www.classiczcars.com/forums/topic/52647-engine-only-runs-with-starter-fluid/?&page=8#findComment-490168 Share on other sites More sharing options...
March 23, 20169 yr Author comment_490170 2 hours ago, Jarvo2 said: I love these SU carbs and have rebuilt many sets over the past couple years. Happy to help out fellow enthusiasts! Its fun turning beat up and worn out examples and refurbishing them. Here are some before & after pics... Those look beautiful. Alot of experience on this board, which I am very grateful for. This is my first vintage vehicle i'm working on lol. Been dealing on modern vehicles my whole life. Carbs are a total new experience for me! At work all I hear i is, "I remember when I used to work on those!". Edited March 23, 20169 yr by hatepotholez Link to comment https://www.classiczcars.com/forums/topic/52647-engine-only-runs-with-starter-fluid/?&page=8#findComment-490170 Share on other sites More sharing options...
March 28, 20169 yr Author comment_490704 So good news and bad news. Good news is, I replaced both needles on the original pots and now both are working properly. Bad news is my rear carb keeps leaking. My plugs are extremely fouled so I'll be changing those out. Should I separate the float bowl from the carb body and then retry the float setup? Link to comment https://www.classiczcars.com/forums/topic/52647-engine-only-runs-with-starter-fluid/?&page=8#findComment-490704 Share on other sites More sharing options...
March 28, 20169 yr comment_490709 14 minutes ago, hatepotholez said: my rear carb keeps leaking Leaking where? How? Link to comment https://www.classiczcars.com/forums/topic/52647-engine-only-runs-with-starter-fluid/?&page=8#findComment-490709 Share on other sites More sharing options...
March 28, 20169 yr Author comment_490717 From the vent after few minutes of running. Also with a slight tap on the fuel bowl it stops. Link to comment https://www.classiczcars.com/forums/topic/52647-engine-only-runs-with-starter-fluid/?&page=8#findComment-490717 Share on other sites More sharing options...
March 28, 20169 yr comment_490740 sounds like your float needle isn't seating. Link to comment https://www.classiczcars.com/forums/topic/52647-engine-only-runs-with-starter-fluid/?&page=8#findComment-490740 Share on other sites More sharing options...
March 28, 20169 yr Author comment_490750 Thanks, if it's not one issue it's another. Edited March 28, 20169 yr by hatepotholez Link to comment https://www.classiczcars.com/forums/topic/52647-engine-only-runs-with-starter-fluid/?&page=8#findComment-490750 Share on other sites More sharing options...
March 28, 20169 yr comment_490752 keep the faith - once you get 'em right, they're rock solid. Link to comment https://www.classiczcars.com/forums/topic/52647-engine-only-runs-with-starter-fluid/?&page=8#findComment-490752 Share on other sites More sharing options...
March 28, 20169 yr Author comment_490754 I hope so... Link to comment https://www.classiczcars.com/forums/topic/52647-engine-only-runs-with-starter-fluid/?&page=8#findComment-490754 Share on other sites More sharing options...
March 28, 20169 yr Author comment_490757 Here are the pics of the alignment tabs. Link to comment https://www.classiczcars.com/forums/topic/52647-engine-only-runs-with-starter-fluid/?&page=8#findComment-490757 Share on other sites More sharing options...
March 28, 20169 yr comment_490772 You can take those float valves apart. Remove that small clip ring at the top and pull the pin out. There's a little cone shaped at the end. Mine are grey in color. There's also a spring in there you can stretch out for a stronger closing pressure. Clean the pin and it's seat inside the body of the valve with a can of carb cleaner. Stretch the spring and it should be like new. Or buy new ones. Link to comment https://www.classiczcars.com/forums/topic/52647-engine-only-runs-with-starter-fluid/?&page=8#findComment-490772 Share on other sites More sharing options...
