June 29, 201510 yr comment_472890 Oops, I guess yours is the opposite problem. The slave cylinder I purchased comes with an adjustable rod. It's exactly the same as the one you have, but longer, and threaded. A nut screws onto it and adjusts the length. I assume to adjust as the clutch wears? Link to comment https://www.classiczcars.com/forums/topic/50727-a-project-is-brewing/?&page=11#findComment-472890 Share on other sites More sharing options...
June 29, 201510 yr comment_472893 Looks great! Wish I was there. My trip got postponed so hopefully in sept I'll be out to turn wrenches... or just drive Link to comment https://www.classiczcars.com/forums/topic/50727-a-project-is-brewing/?&page=11#findComment-472893 Share on other sites More sharing options...
June 29, 201510 yr comment_472895 Nice work, wish I was there as well.Should be a fun first test drive, all that work is going to really pay off ... Link to comment https://www.classiczcars.com/forums/topic/50727-a-project-is-brewing/?&page=11#findComment-472895 Share on other sites More sharing options...
July 3, 201510 yr Author comment_473139 put a sst acorn nut on the end of the clutch actuating rod and it fit fine.go her all together, did a double & triple check, filled w/fluids and gave the key a twist - she sprang to life immediately and after a few minutes at 2500 rpm to make the cam happy i took her out for a lil' spin. the good:the engine runs absolutely amazingly - the balancing and lightened flywheel let her spin up super fast and she's so smooth it's like night and day from the previous motor. idle feels like a new car - you can think it stalled it's so quiet/smooth. revs up to 7K in a blink and sooooo smooth - no vibes at all. the old lump used to rattle the shift lever and make the rearview mirror blurry after 5500, this one is like silk all the way up and pulls great. the bad:transmission woes... i started another thread for advice on this one. 1st whines, almost impossible to get it into 2nd - misses into false neutral, pisses me off - the only part i didn't mess with is the tranny (just replaced front & rear seals) and it's all catywompus... will bleed clutch and if no suitable advice comes i'll have to swap in my old 4sp which works great. Link to comment https://www.classiczcars.com/forums/topic/50727-a-project-is-brewing/?&page=11#findComment-473139 Share on other sites More sharing options...
July 3, 201510 yr comment_473140 I hope mine goes that smoothly- at least the good parts anyway.Congrats Link to comment https://www.classiczcars.com/forums/topic/50727-a-project-is-brewing/?&page=11#findComment-473140 Share on other sites More sharing options...
July 5, 201510 yr Author comment_473213 spent the day pulling out the broken 5sp and swapping in my old 4sp. while i was at it i replaced the clutch master, slave & hose connection. a miserable, wretched job to do - i'm pretty sure i invented some new cuss words in the process. probably a lot easier with a lift, a proper tranny jack and a fluid pump, but i did it on stands on my back using a floor jack and some wood blocks to lever and set the tranny. will see about getting the 5sp rebuilt and have a shop do the next swap - i've got my tranny-swap merit badge and will never do that job again. ever. got to do a few nice runs up & down the street to start breaking in the new motor - it runs fantastic and i'm very pleased with how quiet & smooth it is. next will be installing the 02 sensors and tuning the carbs. after the first few miles i pulled the plugs and they look quite light - not sure if it's lean or if it's the ethanol in the gas. at least they're not covered in crud like the old oil-burning one did. hope to never see this again: Link to comment https://www.classiczcars.com/forums/topic/50727-a-project-is-brewing/?&page=11#findComment-473213 Share on other sites More sharing options...
July 5, 201510 yr Author comment_473216 the sound from the cabin: Link to comment https://www.classiczcars.com/forums/topic/50727-a-project-is-brewing/?&page=11#findComment-473216 Share on other sites More sharing options...
July 5, 201510 yr comment_473219 Getting er done ! Jealous of your quick progress, but not jealous of your trans swap. That's hard on the body. Link to comment https://www.classiczcars.com/forums/topic/50727-a-project-is-brewing/?&page=11#findComment-473219 Share on other sites More sharing options...
July 5, 201510 yr comment_473225 Congrats! Almost there.... we are all hoping for the best. Link to comment https://www.classiczcars.com/forums/topic/50727-a-project-is-brewing/?&page=11#findComment-473225 Share on other sites More sharing options...
July 5, 201510 yr comment_473229 I like your break in procedure. Break it in like you drive it, I learned that with V6 Mercury outboards, run them hard for 1,320 feet and idle back to the trailer. I wish I had've been easier on my body though, my suspension's shot to hell. Oh well, that's why I have a doctor. Link to comment https://www.classiczcars.com/forums/topic/50727-a-project-is-brewing/?&page=11#findComment-473229 Share on other sites More sharing options...
