Skip to content
Removing Panel Retainers: 240Z
  • 8 months later...
I used a length of wood dowel;  it's about 1/8 inch/3mm, but I sanded it to *just* fit through the rivet.  Don't sand too much or the  pin will not do its job. I think I cut them to about 15mm and make the end pointed.  If you take care when removing, you can re-use the rivets, and a 1m length of dowel  was about $1.
  • 2 months later...
I've been looking for alternatives to the push-pin rivets used on the interior panels.
So far I found some rivets like those used to fasten the bumper covers on automobiles.  they have a center 'button' that you lift to disengage the rivet, and you can push it to re-use it again, until it gets brittle.  I found them with a 4mm shank, 12mm shank length, and the head is about 17mm.  I didn't have one from the car, so I had to go from memory.
Otherwise, the closest thing was some click-lock shank rivets from McMaster-Carr.    91020ac2s.png?ver=1304506524
Edited by TomoHawk
