Posted August 1, 200916 yr comment_290911 Dont want a argument like all the other oil threads. I have dug threw them and still cant get a good answer. The question at hand: What oil has the zinc etc etc that are cars require. Please list brands ie: castrol blah blah super blah. Not what is better according to gump just what oils have the stuff we need. Thanks. Link to comment https://www.classiczcars.com/forums/topic/32701-oil-not-a-debate-please/ Share on other sites More sharing options...
August 1, 200916 yr comment_290912 First google hit for motor oil zinc content seems good:http://micapeak.com/info/oiled.html Link to comment https://www.classiczcars.com/forums/topic/32701-oil-not-a-debate-please/#findComment-290912 Share on other sites More sharing options...
August 1, 200916 yr Author comment_290913 what are we looking for zinc content? Most of that data is from 91 i am sure alot of oils have changed. I just dont want to hurt my engine Link to comment https://www.classiczcars.com/forums/topic/32701-oil-not-a-debate-please/#findComment-290913 Share on other sites More sharing options...
August 1, 200916 yr comment_290914 Try this http://mcgeerf.tripod.com/americansyntheticoil/id17.htmlGood luck with an engine that you expect will have metal to metal contact !! Link to comment https://www.classiczcars.com/forums/topic/32701-oil-not-a-debate-please/#findComment-290914 Share on other sites More sharing options...
August 1, 200916 yr comment_290915 Valvoline VR1 has zinc and can be found at Napa or online at Amazon. Autozone and O'Reileys sells it as well, but only 50wt and 20W50. Napa and Amazon have more weights available. Link to comment https://www.classiczcars.com/forums/topic/32701-oil-not-a-debate-please/#findComment-290915 Share on other sites More sharing options...
August 1, 200916 yr Author comment_290916 is that vr1 syn? would prefer a dino oil Link to comment https://www.classiczcars.com/forums/topic/32701-oil-not-a-debate-please/#findComment-290916 Share on other sites More sharing options...
August 1, 200916 yr comment_290918 No, it's not synthetic. They do make it in both dino and synthetic, but I have only seen the dino. Look here. http://www.valvoline.com/products/consumer-products/motor-oil/racing-motor-oil/6 Link to comment https://www.classiczcars.com/forums/topic/32701-oil-not-a-debate-please/#findComment-290918 Share on other sites More sharing options...
August 1, 200916 yr comment_290921 The code phrase seems to be "high mileage". Generally when the oil producer claims a particular oil is formulated for high mileage cars, it has a higher ZDDP content.Personally after weeks and months of researching this subject on the internet, I am no longer convinced that it matters on any overhead cam engine. But if you disagree, the "High Mileage" oils appear to be what you are looking for. (BTW, most of them are synthetic.) Link to comment https://www.classiczcars.com/forums/topic/32701-oil-not-a-debate-please/#findComment-290921 Share on other sites More sharing options...
August 2, 200916 yr comment_290932 Use any oil that explicitly states that it meets or exceeds the performance standards specified by the manufacturer of your vehicle. Many new oils no longer meet the older API performance specs, especially the less expensive ones. Steve Link to comment https://www.classiczcars.com/forums/topic/32701-oil-not-a-debate-please/#findComment-290932 Share on other sites More sharing options...
August 2, 200915 yr comment_290949 Dont want a argument like all the other oil threads. I have dug threw them and still cant get a good answer. The question at hand: What oil has the zinc etc etc that are cars require. Please list brands ie: castrol blah blah super blah. Not what is better according to gump just what oils have the stuff we need. Thanks.What I use is Valvoline Part number VV205 This is VR1 racing oil. I run 10w-30 it has ZDDP. There others but this is a fine quality oil and is readably available. Shell Rotella is another but it must be the NON emissions grade , the same for Dello. In the old days finding oil that meets the API was only what you needed. Now the oils have changed and with roller lifters and Catalytic converters oils have had to eliminate certain important additives . ZDDP being one. On the newer engines it is no longer needed. However with our ''old technology'' we do need the additive. Anytime you ask a oil question , you will open up a debate and we all have opinions. I have mine and it comes form the knowledge of cam grinders and engine builders. I use what I use , you do the same . Nuff said. Gary Link to comment https://www.classiczcars.com/forums/topic/32701-oil-not-a-debate-please/#findComment-290949 Share on other sites More sharing options...
August 2, 200915 yr comment_290957 What I use is Valvoline Part number VV205 This is VR1 racing oil. I run 10w-30 it has ZDDP. There others but this is a fine quality oil and is readably available. Shell Rotella is another but it must be the NON emissions grade , the same for Dello. In the old days finding oil that meets the API was only what you needed. Now the oils have changed and with roller lifters and Catalytic converters oils have had to eliminate certain important additives . ZDDP being one. On the newer engines it is no longer needed. However with our ''old technology'' we do need the additive. Anytime you ask a oil question , you will open up a debate and we all have opinions. I have mine and it comes form the knowledge of cam grinders and engine builders. I use what I use , you do the same . Nuff said. Gary Hey thanks for posting the part number! Amazon sells it by the case! Jeg's is listed in my Google search as well but Jeg's site is apparently down for the moment. I will give this a try my next oil change! Link to comment https://www.classiczcars.com/forums/topic/32701-oil-not-a-debate-please/#findComment-290957 Share on other sites More sharing options...
August 7, 200915 yr comment_291416 I came across this zinc additive on one of the Pontiac websites:http://www.tinindianperformance.com/ZddPlus.htm Link to comment https://www.classiczcars.com/forums/topic/32701-oil-not-a-debate-please/#findComment-291416 Share on other sites More sharing options...
