I saw a Z with a triple SU set up in the old Z car magazine. Looked pretty good, except for the fact the manifold had to be fabricted form scratch, luckily the guy that did it had a father who owned a shop that was capable of melting down scrap aluminum and cast him a new one. The car was up for sale on Ebay not long ago, but don't know if it sold or not. it really was a sweet car. If I remember right he had used a 240 crank in a 280 block for a really short stroke, high revving engine. I'll look for the mag when I get home and try to post a little more info.
https://www.classiczcars.com/forums/topic/2321-triple-sus/#findComment-10860
  • 1 month later...
Seeing triple SUs on a Z would be kind of cool. However, I'm not sure you'd ever get a 2.4L motor to need so much air that the extra carb would help much - I guess when you were turning 8000 RPMs you could have all three carbs half open?
https://www.classiczcars.com/forums/topic/2321-triple-sus/#findComment-14770
Probably not as noticable on a 240, however once you move to a 280 I would suspect that there would have to be a difference.
Reading between the lines of your reply, I'm getting the feeling that your of the opinion that triple carbs on a 240 would be a waste of time and money?
I guess it opens up a can of worms, is there anyone out there that did just that, without altering any other aspect of the engine and can comment on the performance aspect?
https://www.classiczcars.com/forums/topic/2321-triple-sus/#findComment-14780
Hi all,
I have just uploaded a couple of triple SU carbies conversion for a 6 cylinder L series engine from my image collection.
On is of the manifold and the other is the whole package on the engine.
https://www.classiczcars.com/forums/topic/2321-triple-sus/#findComment-14788
I have been running the tripple Webers, with the only other mod being headers. I can assure you that there is a performance improvement.. Though I can not say how much.. The biggest thing I see is much is the engine is a much more responsive throttle... And of course they sound great.
https://www.classiczcars.com/forums/topic/2321-triple-sus/#findComment-14812
Why would you want to? If the answer is because you can.... then great...go empty your wallet.
Triple side drafts are a proven mod and most likely a cheaper option.
The standard SU will flow pretty well with different jets even with a standard L28. But if you have a wild L28 then get the bored by Rebello. Not sure how much they charge but might be worth a email query to them though.
Stick with the obvious.
Just my 2cents......:classic:
https://www.classiczcars.com/forums/topic/2321-triple-sus/#findComment-14815
My opinion on the triple carbs is as follows:
A 2.4 litre engine is cable of processing 296.6 CFM of air at 7,000 RPM. A stock Hitachi SU will flow at 150 CFM, and since there are 2 of them, that's 300 CFM. For a motor that can not turn more than 7K RPM. what good will the 3rd carb do? (Unless you have a more direct air path to the cylinder, maybe.)
If the engine turned 8,000 RPM, the engine can process 339 CFM of air - in that case more carburation is needed, and Triple SUs would be a cool set up.
So my opinion is that unless you're making major engine changes, a triple carb set up is overkill.
https://www.classiczcars.com/forums/topic/2321-triple-sus/#findComment-14837
