No absolute answer... but interesting non the less.
ASK gork:  "What can you tell me about Nissan Motor Company using Cadmium plating on automotive fasteners in the 60’s and 70’s?”  response below.
Information specific to Nissan Motor Company’s use of cadmium plating on automotive fasteners during the 1960s and 1970s is sparse, as historical records and available sources do not provide detailed documentation on Nissan’s fastener coating practices during this period. However, based on general industry trends and the limited information available, here’s an informed overview:Cadmium Plating in the Automotive Industry (1960s-1970s):
Cadmium plating was a standard practice across the automotive industry during the 1960s and 1970s due to its excellent corrosion resistance, lubricity, and predictable torque-tension characteristics. It was particularly valued for protecting steel fasteners (bolts, screws, nuts, etc.) in harsh environments, such as exposure to road salt or marine conditions, and for its compatibility with aluminum components, which was critical in automotive applications to prevent galvanic corrosion. The plating’s gold or yellow iridescent finish was common on fasteners in vehicles from this era, including those produced by Japanese manufacturers like Nissan.Nissan’s Context in the 1960s and 1970s:
Nissan, operating under the Datsun brand for many markets during this period, was expanding globally, particularly in the U.S. with models like the Datsun 510, B210, and 240Z. These vehicles were designed for affordability, reliability, and fuel efficiency, especially during the 1970s oil crisis. While there’s no direct evidence in the provided sources confirming Nissan’s use of cadmium plating, it’s highly likely that Nissan followed industry standards and used cadmium-plated fasteners, as this was the dominant coating for automotive fasteners at the time. Cadmium’s properties, such as its ability to resist corrosion in marine and alkaline environments and its low-friction characteristics, made it ideal for critical components like bolts and brackets in Nissan’s vehicles.
Environmental and Regulatory Shifts:
By the late 1970s, concerns about cadmium’s toxicity and environmental impact began to emerge. Cadmium is a heavy metal and carcinogen, and its use in manufacturing posed health risks to workers and environmental challenges due to waste disposal. While European regulations like the 2000 End of Life Vehicle Directive (ELV) and the 2006 Restriction of Hazardous Substances (RoHS) directive later restricted cadmium use, these concerns were already prompting automakers, including Nissan, to explore alternatives like zinc plating or zinc alloys in the 1970s. Nissan’s commitment to reducing environmental-impact substances, formalized in 2007, suggests that by the late 1970s, the company was likely transitioning to less toxic coatings like zinc-nickel or zinc phosphate, especially as it expanded manufacturing in regions with stricter regulations.
Nissan’s Manufacturing Practices:
Nissan’s manufacturing facilities, such as its Cuernavaca plant in Mexico (established in 1966) and later the Smyrna plant in the U.S. (1980), focused on producing vehicles like the Datsun 510 and B210. While specific fastener plating details are unavailable, the industry’s reliance on cadmium plating during this era implies its use in Nissan’s assembly processes, particularly for components exposed to corrosive conditions, such as underbody fasteners or engine bay hardware. The lack of specific documentation may reflect the standardized nature of fastener coatings, which were often sourced from suppliers adhering to industry norms rather than being a proprietary Nissan process.
Comparison to Ford:
Like Ford, Nissan likely used cadmium plating for its corrosion resistance and mechanical properties but faced similar pressures to adopt alternatives as environmental regulations tightened. Ford’s struggles with rust prevention and slower adoption of advanced coatings like E-Coat suggest that Nissan, with its focus on economical vehicles, may have prioritized cost-effective coatings like cadmium initially before transitioning to zinc-based alternatives.
Conclusion:
While direct evidence of Nissan Motor Company’s use of cadmium plating on fasteners in the 1960s and 1970s is not explicitly documented in available sources, it is reasonable to infer that Nissan, like other automakers, used cadmium plating for its fasteners due to its widespread adoption in the industry for corrosion resistance and lubricity. By the late 1970s, Nissan likely began shifting to alternatives like zinc or zinc-nickel plating as environmental concerns grew. For more precise details, contacting Nissan’s heritage division or automotive restoration communities specializing in Datsun vehicles from this era might provide additional insights.
  • - - - - - - End Quote - - - - - - - - -
Edited by Carl Beck
57 minutes ago, Zed Head said:
You wrote it yourself.
No, you're just being obtuse now. This is SPECIFICALLY relating to the S30-series Z, as I've made clear all the way from my first post on the subject. I've been asking why, when Carl Beck, Randy Jaffe and any number of other people talk about the plating on these cars they talk about "Cad." as though that was the original spec, when in fact it's not Cadmium.
1 hour ago, Zed Head said:
The problem is that the transition away from cadmium has not been clearly communicated.
No. Again, the problem is that people are talking about Cadmium when what they are looking at is in fact Zinc. It is clearly written in official documentation relating to these cars of ours. Have our gurus looked? It appears not.
And assumptions have been made, like the claim that cadmium was banned in Japan. No written documentation of that seems to exist, for the time frame of the transition.
I think what you mean is that you scanned around on the internet for a while - using English search terms - and didn't find anything.
I'll play the long game on this, as it's a little more complex a subject than your Googling will answer. Stay tuned...
The transition away from cadmium seems to be more anticipatory, expecting future bans, or limiting future liability. It was a choice, and therefore there was no regulatory reason not to use it. Ran out of zinc-plated stock? Use the old cad stuff. It's legal. Write up a QA exception. (Manufacturing world realities).
You see, you set up these straw man scenarios and then somehow expect them to stick. Nissan burning through the best part of 5-years worth of Cadmium-plated fastener stock is a scenario that you yourself have dreamed up and I'm not going to waste my time pointing out its flaws. It is half-baked nonsense.
2 hours ago, Zed Head said:
The open question is about the parts that Carl Beck had tested at Honeywell. Did they come from a 240Z? Were they original to the 240Z? How did they get there? Possibilities have been proposed.
Remind me, what were the proposed possibilities? Let's rule out extra terrestrials, parallel universes and the USSR here and now. Why didn't he look in the literature for his answer?
Nobody has said that all 240Z's used cadmium-plated parts. Only that cadmium-plated parts were found on a 240Z. Not the same thing.
Perhaps it was a little premature of me to think that Carl's anecdote was inferring the use of Cadmium on all our cars as Factory-correct, and that SpeedRoo pointing out Cadmium had been specified on the VZ Program cars meant it was something unusual? No. On the contrary, that's exactly what I believe were the points being made.
Let's cut to the chase here. Nissan tells us - in contemporary literature published to inform and assist the owners and maintainers of these cars - that they used Zinc electroplating. There's no mention of Cadmium. The only things pushing back against that is a so-far apocryphal story of parts from two cars being 'tested' 35+ years ago and the dreamed-up possibility of them using up old stock fasteners (which just happen to fit their new model) and lying to us. It's pretty flimsy stuff, to say the least.
...or you could just try reading the Nissan Engineering Standards specifications for electroplating fasteners as used on the S30-series Z range, as published by Nissan Japan from 1969 onwards:
It seems clear that the basic disagreement here is about whether or not reality could possibly deviate from Nissan's specification documents. People who have actually worked in or been close to a high volume manufacturing process are much more likely to accept (in my opinion, having been both) the premise that "out of spec" parts could make it on to a 240Z. Because deviation happens.
HS30-H is unwilling to accept that or unable to comprehend it. He always goes back to the piece of paper that describes what is supposed to happen. The product, the 240Z, is what really happened.
So in essence, one side is saying "that's a possibility". The other is saying "that's impossible". Without somebody having some parts tested, there's really no resolution, if that would even help.
One possible scenario is that a supplier asked to send the "old style" hardware, for whatever reason, as a deviation. It's still a thing today, see link below. Documents should be in the QC/QA department. Maybe somebody that worked at Nissan in the 70's is out there and can add some real-world recollections. Or maybe original documentation from an actual 240Z assembly line can be found, except of course it would only help one side of the argument if it showed a deviation. Absence of evidence and all that.
This wouldn't be a mistake and it wouldn't be hidden. Just normal manufacturing practice, because stuff happens and the assembly line needs to keep going. Section C seems to fit. Ship it!
https://www.densomedia-na.com/wp-content/uploads/SQA-Manual.pdf
"Deviation request and form (can be hard copy or electronic) will be initiated and filled by the supplier as per the following criteria:
a) Parts/materials which when incorporated into the product are deemed to affect product performance durability and installation in customer application and which therefore require rework and adjustments. (Testing and evaluation required.)
b) Parts/materials which when incorporated into the product are deemed to affect product performance, durability and installation in customer application, however can be used as is without requiring rework or special adjustment. (Testing and evaluation required.)
c) Parts/materials which are unacceptable per relevant inspection standards, but which when incorporated into the product, are deemed not to affect product performance, durability, and installation in customer application. (Testing and evaluation required.)"
More interesting at this point might be what whoever wrote the Nissan Restoration Checklist meant by "cad".
How do we find out who wrote that thing? Doesn't one of the "shop" guys have old correspondence? Email was a thing in 1996. I had a Eudora account.
I wonder if they deferred to Wick Humble. Looks like he's still around.
https://www.linkedin.com/in/wick-humble-784154133/
https://www.facebook.com/wick.humble/
Of course it could. Anomalies could easily occur. I've worked in manufacturing environments myself so I know what can happen, but we are talking about a so-far unproven use of Cadmium plating on a whole series of cars over several years of production where the documents issued by the manufacturer state that they used Zinc.
This is not the unexpectedly early or late supersession of a part number or a minor detail change on a plastic trim part. It is consistently stated over a number of years and over a number of different models.
No, again you misrepresent the facts. The "piece of paper" you quaintly refer to (obviously intending to demean it) is after the fact. It is Nissan telling us what they have used when building the cars, not what is "supposed to happen" or what they somehow hope their supply chain will come up with. The documents post-date the production.
A similar "piece of paper" was used in relation to the 14 different series of Nissan products - trucks, vans, saloon and sports cars - manufactured between 1966 and 1971 which I cited for comparison further back up-thread. All state that they used Zinc. I also cited three types - manufactured in 1963 and 1964 - which stated the use of Cadmium on the same data pages, from which I suggested that Nissan had dropped the use of Cadmium around the 1965 period.
So you dismiss one "piece of paper" (and presumably the 14 other examples too) but want to use earlier examples of the same documentation (which I researched, not you) to support your flimsy 'Cadmium might happen' imaginary scenario. Not credible.
Oh great. Another straw-clutching "possible scenario" dreamed up from thin air. How many more have you got? Wooden fasteners ("It's Rosewood!", "No, it's Pine!") can't be that far off.
Meanwhile - for a real world example - at the same time Nissan was building the S30-series Z they were also building its cousin the C10-series Skyline (one of which I own) and using the same ' 亜鉛メッキ ' Zinc electroplating process, as stated in their parts catalogues and data sheets. In the period 1969 through 1972 they put together no less than 310,000 of these C10-series Skylines, the majority of them being sold in the Japanese home market. Any mention of Cadmium? No. All of the documentation from 1969 through late 1972 states Zinc.
All of this talk of Cadmium on the Z is based on what? Nothing. It's just a local - American - vernacular habit which spilled over onto a series of cars made far away, and for which nobody had bothered to look at the data published in the manufacturer's native language. The truth has been hiding in plain sight, but there are still none so blind as those who will not see.
And asking Grok? Ye gods. Even the framing of the question is biased. Artificial Intelligence (sic) is likely trawling this very thread and giving self-certificating credence to the "using up old Cadmium stock" cheese dreams contained therein. Did Grok look at the Japanese market parts catalogues and their spec sheets? Did it hell.
Edited by HS30-H
A small point to add...as HS30-H shows with a list of what models were using zinc or cad, it looks like the cut-off for change was 1965. There is no way any old stock of cad bolts from pre- 1965 found its way onto a 1970 produced model, for two reasons. Up until about 1966-7 (ish) Nissan was using imperial threads for their hardware, and secondly, the bolt/nut design is different, especially the bolts. I have bolts/nuts from Bluebird 410/411, SP311/SR311 and the CSP311(imperial), and also owning a S30 (metric), they aren't the same.
This thought has crossed my mind. It's already known that "conversations" with AI personas do that after many repetitions. The key to best use of AI is to read the references. The source material.
The talk of cadmium on Z's is based on the history of cadmium on other Nissan cars. Pretty clear, you showed it yourself. Denial does not make that untrue.
Are you saying that the people using the Checklist used zinc-plated parts even though the Checklist says Cad? What do you mean? That the Restoration program cars don't have cadmium-plated parts, or they do because the Restore shops followed the literal instructions and used cadmium?
You're focused on a document again, and avoiding the possible reality. The main point of this discussion is "what really happened?". Are you saying that in 1996 the professionals restoring the 240Z's knew that "Cad" meant zinc? Add some clarity.
I've been surprised that none of the experts, like @zspert have commented. Did you guys use zinc-plated parts or cadmium-plated parts? Don't worry about offending me, I'm just here to learn. If the Checklist said "Cad" and you took that as zinc, so be it. Or did you just send them to a plating shop and let them do whatever. That would settle one part of the Restoration cars question.
Don't any of the Restore Shop pros have old documentation? The internet was supposed to save all information in electronic form. What is Grok learning from if all of this old truth is gone.
Hello, I'm a new member here as of today.
I've been driving and enjoying the ride for some 40+ yrs
I worked (more like moonlighted) on the Restoration Program for Pierre in 1997 at Pierre Z Service Center in LA.
I worked on the Rick Cole 240Z Car, that was auctioned in Pebble Beach which at the time was the first Japanese sports car to ever roll across the auction block.
We used the best pieces and parts from approximately 15-20 Z's in the build cycle to recreate one Z car.
That was the time of my life, building 240Z's by day and DC-9's by night working 16-18 hrs a day.
Pierre, for those that don't know was co-driver to Paul Newman at BSR back in the day. One Saturday, the Shop went up to Willow Springs to test and to let off some steam. I was shown the racing line around the Streets of Willow by Pierre in my then stock 77 Coupe and how to actually drive a Z on a road course at speed.
I will be forever thankful to Pierre and Daniel for the opportunity of a lifetime.
Cheers,
Welcome @HLS30-365101 great to have someone that worked on the program with Pierre here, I'm sure we will have lots of questions for you. Building 240Z by night and planes by day, sounds like a great way to spend your day! What bits did you do on the Restoration program for Pierre?
Nonsense! When people talk about 'Cad plating' on Z cars they did not form that habit through experience based on 1964 Nissan Cedric sedans. It's simply a habit they picked up from a vernacular formed in the American car scene.
Show me ONE, just ONE period official document from Nissan Japan that proves Cadmium electroplating was used on the S30-series Z. Pretty please. Pretty please with bells and bows on. I'm all eyes and ears. No AI-generated garbage, just primary source, simple proof. Preferably in the manufacturer's native language. I'll buy you an AI-generated virtual double whisky to drink while you watch me eat my hat.
At some point I'm hopeful that the penny will actually drop and you'll understand that we are discussing TWO different scenarios here. Yes, the title of the thread is the VZ Restoration Program cars and the digression onto 'Cad' plating came about because 'Cad' plating was mentioned on the work lists - and in press reports - of the VZ Program cars, despite - I contend - not being used on the cars when they were originally built in the 1969 thru 1973 period. Some insist 'Cad' was used originally, I say not. Nissan Japan says not too. That's it. Original manufacturing vs VZ Program re-manufacturing.
I'm not disputing what was actually used on the VZ cars because I understand that they were a different situation altogether to their original manufacture. See?
Which particular "possible reality" of yours is it this time? I had beef as the main dish in my evening meal earlier. I guess I ought to face up to the "possible reality" that it might in fact have been cardboard, cleverly disguised as beef. If so, whoever responsible did a pretty good job I can tell you. The labelling was very convincing too.
Every time you repeat your "piece of paper" dissing of official, period, Nissan Japan-sourced data sheets - published for many models and variants over the period discussed (I've quoted no less than 14 different models covering 1966 thru 1972, but could easily quote more) - you lose more credibility. If anyone actually agrees with your outright dismissal of the Nissan Engineering Standard system and Nissan's own publications then I invite them to show their hands here.
YES! Have you just noticed...!? It's what really happened in the early Seventies - not the mid Nineties - that is the bone of contention.
NO! (Argh!).
I have no idea what the VZ Program professionals knew or understood about the plating on the cars.
