LF fuel injectors - Page 6 - Fuel Injection - Classic Z Car Club Skip to content
LF fuel injectors
I went through a pretty thorough alternate injector search back when I was trying to solve the "hot start" problem. I found that these early injectors were at the very low end of the flow rate spectrum. If you find a later injector that you want to try you will probably need an adjustable FPR. Also, most later injectors used 3 bar (~43 psi) instead of 2.5 (36.3). The early injectors are just very primitive. Not many choices out there.
I didn't download that link, but I did dig up an old web site that somebody put together that might be worth a browse.
http://users.erols.com/srweiss/tableifc.htm
that is the one I also found. I managed to save the info on my HD in case the site disappeared.
Edited by kickstand80
