Skip to content
83 280ZX 5 Speed (non-Turbo) Transmission FS5W71B
I have used this transmission in my Z for many years. After putting many miles on it over a number of years, I decided to rebuild it because it was grinding a bit when going into second. I rebuilt it myself using all new OEM bearings and synchronizers. I also replaced the seals/o-rings on the main selector rod. It has had little mileage added since the rebuild. It is in very good condition. I am switching to a 240SX transmission, so I no longer need this one.
Price: $600 plus shipping or you can pick it up from Marietta, GA.
Gear ratios:
First
3.062
Second
1.858
Third
1.308
Fourth
1.000
Fifth
0.745
Not included are the speedometer cable and the series one transmission crossmember, though I will sell the crossmember separately.
I let a couple of friends in the area know about this in case they know of someone looking for a 5 speed.
3 hours ago, mayolives said:
Sounds like a deal to me!
Yep, especially when someone in Alpharetta (near @inline6 ) posted an 83 5-speed that wasn't even cleaned up for $700.
Please let me know if this is available. I am in Cumming, but will be in Marietta Thursday evening. I can pick it up then.
Edited by WolfZee
Hi WolfZee,
A transaction is in progress. If anything should change, I will let you know.
