Rough cold idle then smooths out - Page 11 - Fuel Injection - Classic Z Car Club Skip to content
Exact same coil I have that I bought on Amazon 3 years ago. Feel like we’re going down a rabbit hole here. 1.5 ohm coil per spec.
Edited by Yarb
Pic
@Yarb PMing for the coil now
@Zed Head why are these so rare? there are so many of these cars out there - you'd think coils would be available...
Edited by chaseincats
1 hour ago, Zed Head said:
He just wants to use the factory specification from the FSM.
That's not spec. There's no rabbit hole here. I'm sure it will work just fine. I'm just going by the words people write.
Just trying to help out. Hopefully he finds the coil he needs
https://www.jegs.com/i/ngk-spark-plugs-739-u1099-oil-filled-canister-ignition-coil-chrysler-daihatsu-isuzu-mitsubishi-nissan-subaru
It’s available. Not sure what you searched. “Jeggs” is the second most supplier of automotive performance products behind Summit. Hopefully they have it in stock. They do show a ship date.
Edited by Yarb
Just checked again and did not show unavailable. Have one in my cart ready to ship.
you rock, thanks for this.
I also wanted to chime in about the cap/rotor. When you buy a replacement check to make sure the cap fits snug. After installing it, make sure there's no play or movement of the cap. Grab it with your hand and rotate/wiggle the cap to make sure it fits. Cheap ones will move but the good ones will fit tight. You don't want any movement of that cap.
