Skip to content
What’s my first move??
Is your tachometer connected, with the inline resistor in place? I had found in the past that my 76 and a 78 parts car would not start if the tachometer was disconnected. It appears to do something to the signal on Pin 1. I never figured out what, but I did confirm it a couple of times. On the 78 I had the tachometer out and on the 76 I had the resistor removed which disconnected the tachometer.
8 hours ago, Zed Head said:
Seems like the main question is "what happened between then and now?" The cracked AFM hose could stop the AFM from functioning, but the engine should stil start for a few seconds on cold start injector fuel.
Maybe your spark is too weak. Are you seeing s strong blue spark or a weak yellow spark? You might try starting fluid to see if you can get it to fire for a few seconds.
Another possibility is flooded/fouled plugs. Have you pulled a spark plug to see how it looks? I'd do that, it's easy and quick.
I installed new coil, plugs, wires, cap and rotor. Spark was weak not enough to cause a no start I believe.
Tachometer is connected and where if any is the resistor? I found this barely grounded to the distributor what is it? IMG_CA160276-52DA-4A31-B1EF-40341A18BA9E.jpeg
8 hours ago, dtejada said:
Tested injector pulse just now and drops form 12.5 to 10.4 both sides of the pin and no pulse.
The best way to test the injector circuits is with a fast-acting light like a NOID light or with a spare injector. If you find that the injectors aren't being opened by the ECU then you can focus on that. But you might find that the injectors are being "commanded" open but aren't. They can rust shut. Or maybe they are opening but they're squirting water. Maybe you put 5 gallons of diesel in by accident. Just kidding but the point is that you seem to have everything you need except good fuel squirting. If it starts with starting fluid you have spark and proper timing.
Is your cold start valve still installed and connected? It's easy to remove and you could check that it is squirting good gasoline during the start procedure. You could also install it on one of the injector connectors, I think it uses the same EV1 connector. I've never tried that though. Could be interesting. Don't forget that the hose will be pressurized if you remove it from the hose. If you can keep it connected to fuel but get an injector connector plugged in it might tell you something.
But really, a NOID light is the way to go.
Edited by Zed Head
