Oil pan help?? - Page 2 - Open Discussions - Classic Z Car Club Skip to content
Oil pan help??
3 hours ago, Zed Head said:
Thanks for replying. From out here, the post reader, the sigh sure does look like a comment. Just couldn't tell what the comment was about.
Instead of saying "good morning" like normal I say "sigh". LOL
It's never good.
1 hour ago, texasz said:
Which ZStory header are you getting?
When I spoke with Sean @ ZStory, he recommended the Street-sport or Race-sport for my build. I'm leaning towards the street-sport, but as my build increases in cost, I may just re-use the MSA header I have for now and get the ZStory later, especially with the tariffs and all...
Ok, I got the race-sport header and can confirm that it will not clear the oil pan with the heatshield. I of course learned this after the engine was in the car and was not about to remove it so I rolled up under the car with a Dremel and cutting wheel to cut the heatshield off. Once that was done the header fit just fine. Hope this helps keep you from being covered in sparks cutting the heat shield off after installation like I was. :)
Now THAT is the info. I was looking for! THANK-YOU!
Sean will want to talk to you personally wanting to know what you are working with before he ships you one of his headers.
Did you read my post?
7 minutes ago, texasz said:
Yep, I read that one and that is what caused my post. I have the oil pan from the turbo motor, and I have the oil pan from the original L24. I can use either, but they both need re-habbing before I can use them. I didn't want to have to re-hab both of them at this time, but I think that is what I'm going to do, as they will both need to be done at some point anyway.
Since I have the pan out for cleaning up, I have the ability to modify/change/omit the heat shield from the turbo pan. Can you explain what part interferes with the header? I'm thinking I may be able to retain some heat-shielding of the gasket and still fit the headers? I'm actually considering just using the MSA header I have for now until I can save some more dollars for the ZStory headers and hopefully, the tariffs will expire as well!
I've also read that the turbo oil pan may not fit into the 240 because of the sump being in a different spot from the 240 pan, and causing interference with the crossmember, but I haven't been able to confirm that either.
