3 hours ago, Zed Head said:
Thanks for replying. From out here, the post reader, the sigh sure does look like a comment. Just couldn't tell what the comment was about.
Instead of saying "good morning" like normal I say "sigh". LOL
It's never good.
1 hour ago, texasz said:
Which ZStory header are you getting?
When I spoke with Sean @ ZStory, he recommended the Street-sport or Race-sport for my build. I'm leaning towards the street-sport, but as my build increases in cost, I may just re-use the MSA header I have for now and get the ZStory later, especially with the tariffs and all...
Ok, I got the race-sport header and can confirm that it will not clear the oil pan with the heatshield. I of course learned this after the engine was in the car and was not about to remove it so I rolled up under the car with a Dremel and cutting wheel to cut the heatshield off. Once that was done the header fit just fine. Hope this helps keep you from being covered in sparks cutting the heat shield off after installation like I was. :)
Now THAT is the info. I was looking for! THANK-YOU!
