Posted
I have an later e88 with SUs and ZX dizzy, e12-80 on my 240. I've read a lot of different stuff on the plug gap. Half say go with the motor and the other half say go with the ignition. Motor says protruding with .035ish gap. Ignition for '79 says non protruding .044ish gap.
I like to think it has the strong spark at .035 protruding for carbs. I opened them up to .042 on bpr6es-11 and it didn't run too good. What do you all think? I also read that a closer gap on the 1.1mm would angle the tip downward too much and you don't want that. I think I should buy these instead of the 1.1mm
https://shop.advanceautoparts.com/p/ngk-standard-nickel-spark-plug-bpr6es-reliable-oe-performance-4008/18090163-p?product_channel=local&store=6668&adtype=pla&product_channel=local&store_code=6668&&&&&gclsrc=aw.ds&gad_source=1&gad_campaignid=16396150477&gclid=CjwKCAjw6vHHBhBwEiwAq4zvA_2SIcXPfpN8WAkuS9dMgo6W_K-pa5oGWg56uecTiat8BKKgmfmKTRoCxtAQAvD_BwE
Thank you for any input.
https://www.classiczcars.com/forums/topic/69616-240-with-e12-80-plug-gap/
