Measuring resistance from 7 to 8 will provide difficult to interpret results. The best way to check the AFM slider is to put battery voltage across 9 to 6 (positive on 9, negative on 6), and then measure the voltage between 7 and 8 while you move the wiper around. This process is documented on page EE-13 of the 77 FSM)
The AFM is Dr. Bosch black magic and voodoo.
As for the dent in the wiper? I don't know what you mean. Can you circle what you're talking about on your pic?
