I bought the seal from Nissan, p/n 32709-14600 if that's the one you need. Mine is a manual but the speedo housing should be the same. There's some more info in this thread.
Here's some for sale...
https://www.google.com/search?q=32709-14600&rlz=1C1VDKB_enUS1121US1121&sourceid=chrome&ie=UTF-8
Edited by siteunseen
From the thread, "That little Top Hat in the pictures only comes with a new Speedo cable.
However all is not lost. It is just a secondary seal. You can go to home depot and get a flat rubber washer that will do the same thing.  They come in various sizes and have approx a 1/8" dia inner hole." @Chickenman
Chances are it’s leaking on the speedometer housing itself. It’s been a minute but if it’s like the manual transmission there’s an O’ring and a seal like @siteunseen mentioned.
I really don't know about auto transmissions but seems like my auto Camaro I had to check hot and in gear with the E-brake on if I'm not mistaken. Have you recently put fluid in? Could just be slight over fill? Good luck with it no matter what.
