1 minute ago, Yarb said:
Brake line is quite different than the bleed system. IMO go back and do it by having that bleeder open. You might be going down a rabbit hole here.
Haha, rabbit hole for sure. Sitting on the bench, with the caliper taken apart in 2 pieces, the brake pads "piston" ought to be able to compress without having to open the bleeder, correct? The fluid should go back the way it came from. Anyway, how hard should it be to move the piston? Can you compress it by hand or do you need a C clamp like I did?
Edited by Parman
Not sure what you mean by two pieces. But if it's sitting on the bench then, obviously, there's an open port to atmosphere. No way to hold pressure.
The piston should be easily moved by hand if the caliper is new or newly rebuilt and has had fluid in it. Or maybe not, re above. Where did you get the calipers? Might have a bad rebuild. Tight seals.
Edited by Zed Head
If you have a caliper on the bench you might as well pop the piston out. Don't scratch the cylinder with the metal dust seal retaining ring.
Images won't load but the Brake chapter describes it.
Uploading Attachment...
I very much appreciate all you guys. I believe they are the original calipers, I rebuilt them. When I had the one on my bench, I tried blowing the piston out of the inside half with compressed air, but trying to hold my fingers over the 2 holes leading to the other half, I didn't like where it was going, so I stopped. Never did move the piston out. I may have not assembled them right, lack of grease possibly, I don't know yet. I have my first car show locally tomorrow 15 miles away, so rather than break this system apart now, I'm going to wait until next week. Then I'm going to disassemble a caliper and see why those pistons are so hard to move.
