Low power/Lean when fuel is low - Page 3 - Help Me !! - Classic Z Car Club Skip to content
1 hour ago, chaseincats said:
I've been thinking about this recently. What do folks usually do about this?
Get the tank fixed or get a new tank from S30.World
Again, S30.World Your issues will no longer exist. Had my 78 repaired and sealed twice and it still leaked through pin holes that developed with time.
On 2/8/2026 at 11:47 AM, chaseincats said:
I've popped the top open and the tank itself is fine since it was boiled out/coated about 10 years ago and there isn't any rust on the walls.
Would I need to take the car to some sort of specialty shop to have them fix the intake pipe? I have no idea what kind of place I should be looking for.
On 2/7/2026 at 11:45 PM, chaseincats said:
Since I have that pinhole air leak in the tank's pickup tube (not visually confirmed but the theory checks all of the boxes considering the symptoms), I can't drive the car past a half tank before it beings to run lean again (confirmed by my air/fuel ratio gauge)
If you had the tank out with the top open sitting in front of you then I'd suggest confirming that you have a leak in the intake tube. What do you mean by "pop the top open", anyway? Has it been cut open and rewelded in the past? Don't remember your history.
If you have the time and want to save money then pull the tank and take it apart to confirm the pinhole. If it was mine I'd cut the leaking tube off with a tubing cutter and use a compression fitting to put a new piece in. But I'm cheap and like to improvise.
Don't forget that everything before the pump is under suction when the pump is on. There are other places to suck in air. You need to confirm the source of your problem before deciding on a solution. You might be able to figure it out with a bore scope down the filler hole.
No image preview
Basics of Compression Fittings
Compression fittings are a type of coupling used to connect two pipes or a pipe to a fixture or valve. Read on to learn more!
@Zed Head I’m not frivolously trying to spend his money. I spent over $400 trying to have a 35 year old tank at the time to be repaired. Bottom line is these tanks develop pin holes especially around the seam of the tank. My opinion was if he wants to save money in the long run and close this particular variable this is a viable solution.
It was just an observation. He says that he thinks that he has a pin hole in the supply tube. Not the same as pin holes in the tank itself.
I wonder what the bigger swirl pot looks like. They talk about it but didn't include the pictures. Apparently they deleted the filter sock also.
https://shop.s30.world/product/07-77-till-12-78-datsun-280z-fairlady-z-fuel-tank-vapor
"As seen in the pictures we deleted the internal filter and made a bigger swirl pot with a big baffle. The tank need to be operated with an external fuel filter."
Total cost $830.
Tanks are here at there whs in the US. when I ordered mine. Not sure if that’s changed. Just took a look and the shipping is a bit higher. Wisconsin to Florida was $95 2 years ago.
Edited by Yarb
Probably have to contact them to be sure. I put one in the cart and went to checkout. Says it's shipped from Europe. If it was here it seems like it would show that. And, if it's in Europe I'd guess that tariffs will apply to get it in to the States. Also, sales tax in certain states. Not sure where CIC is. 6.5% in WA.
Just researching to get a full picture.
Cart totals
Subtotal US$665
Shipment
Flat rate: US$165
Shipping to United States (US).
Change address
Total US$830
Edited by Zed Head
