3 hours ago, gotham22 said:
. At idle, the pressure reads 32 psi. When I manually move the throttle, it increases to about 38 psi.
This normal. It also shows (edit) pretty good intake system vacuum. 30 psi or below at idle is normal. Have you adjusted the valves recently?
If I had this problem I would check the TVS (aka TPS). Make sure it's working right at open throttle. It's what adds the extra fuel. Your fuel pressure looks good.
Edited by Zed Head
On 5/6/2025 at 2:55 PM, siteunseen said:
Hooking up a vacuum gauge is somthing else that helps find problem. You can get them at chain stores with loaner programs for free.
Here's the link -
https://www.atlanticz.ca/zclub/techtips/vacuum/
What condition is your EFI harness? Have you replaced all of the connectors? I fought it forever. Finally reworked and soldered each connector, cleaned each contact and was amazed.
  • 4 weeks later...
I’m not sure, maybe you’ve worked this out while I’ve been in exile. I have to assume stock L-Jetronic EFI?
If so, open the air flow meter and tighten the spring a bit.
