Just to add to this, there are also some additional numbers stamped, not cast, into both sides of the outside face of the caliper. In the images are NOS left hand and right hand calipers, with both faces shown, along with the date stamped box (which looks like 10th May 1979, albeit the bottom part of the second 9 is missing), for the LH caliper. This does correspond with the "date" number on the caliper face.
OK, so another data point that lines up. So unless someone else comes up with something better, I'm going with what we got.
@SteveE, It was your pics that turned the corner for me. I had some 70 calipers here that were "0" year and a 78 pair that were "8", but I just couldn't believe it was that simple. Then when you posted your pics of your 8/72 build calipers that were all "2", it seemed that it WAS that simple. Thanks again!   :beer:
  • 8 months later...
With 12 months and only 1 digit, what does Nissan use for the last three months: "A" and "B"? Or something else? I have caliper here that has "X" in this position. Maybe the 10th, 11, and 12th months are "X", "Y", and "Z"?
Edited by Broman
