I am installing NOS storage covers and want to minimize the possibility of them breaking at the fastening knob.
Has anyone devised a method to reinforce the cover edges?
Thanks,
Keith
Edited by zed2
https://www.classiczcars.com/forums/topic/67814-series-1-storage-covers/
Hi Keith, I think it is because of lack of courtesy not of the plastic. It is bothering but every time I open the storage covers , I unscrewed the knob completely out not to pinch the edge of the cover .
I put a washer under the screw , I don’t know this helps something anyway.
Kats
You are dealing with 50+ year old plastic here that will have gotten more brittle over the years. Consider bonding a thin reinforcement on the underside - one solid strip with a notch to match the factory shape. That plus @kats recommendation for a thin rubber washer under the knob should help hold back breakage.
Edited by jfa.series1
I, too, have a pair of NOS storage covers on my Z.
As Kats said, I take the hold-down knob off completely,
and use a fairly thick and large black rubber washer for
a bigger footprint and flexibility for soft, even pressure.
