June 28, 20196 yr Author comment_578564 Well I got the pressure gauge but I can’t find a t connector anywhere, this really sucks I’ll have to look online I guess. Link to comment https://www.classiczcars.com/forums/topic/62337-78-280z-idle-problem/?&page=7#findComment-578564 Share on other sites More sharing options...
June 28, 20196 yr Author comment_578566 1 hour ago, Dave WM said: The wiring of the CTS and the CSV can get mixed up, bullet connectors and sensor plugs that can interchange. That's why its important to check at the 36 pin connector, it will account for any mixups. My guess is that pin 13 to ground will be wide open. What is the 36 pin connector? This is probably a stupid question but I am unfamiliar with it Link to comment https://www.classiczcars.com/forums/topic/62337-78-280z-idle-problem/?&page=7#findComment-578566 Share on other sites More sharing options...
June 28, 20196 yr comment_578567 That is the connector on the ECU down next to the drivers left foot. Link to comment https://www.classiczcars.com/forums/topic/62337-78-280z-idle-problem/?&page=7#findComment-578567 Share on other sites More sharing options...
June 28, 20196 yr comment_578572 18 minutes ago, Jack Pearcy said: Well I got the pressure gauge but I can’t find a t connector anywhere, this really sucks I’ll have to look online I guess. just plug into the line that goes to the CSV, you don't need it anyway during summer months and it removes one more variable (a bad CSV) from the equation. Link to comment https://www.classiczcars.com/forums/topic/62337-78-280z-idle-problem/?&page=7#findComment-578572 Share on other sites More sharing options...
June 28, 20196 yr comment_578573 if your are reading how to do the test you will already know this, but just in case you missed it. Before disconnecting the 36 pin connector turn off the ignition, and disconnect the battery. Its a bit of over kill doing both but you don't want any possible voltage spikes from connecting and disconnecting the ECU with voltages present. Exercise care when probing the 36 pin connector, you don't want to deform any of the sockets by sticking a prob in forcibly. if you have not already don't forget the importance of making sure the connections under the hood are clean. Corrosion is a big problem, You may seen green corrosion on a plug end, it often will creep up a wire. Take pics of anything that looks like that so we can see. We are depending on you to be the eyes and ears. its very hard to diagnose things remotely with out using your senses (no OBD with these old cars). Edited June 28, 20196 yr by Dave WM Link to comment https://www.classiczcars.com/forums/topic/62337-78-280z-idle-problem/?&page=7#findComment-578573 Share on other sites More sharing options...
June 28, 20196 yr Author comment_578585 22 minutes ago, Dave WM said: if your are reading how to do the test you will already know this, but just in case you missed it. Before disconnecting the 36 pin connector turn off the ignition, and disconnect the battery. Its a bit of over kill doing both but you don't want any possible voltage spikes from connecting and disconnecting the ECU with voltages present. Exercise care when probing the 36 pin connector, you don't want to deform any of the sockets by sticking a prob in forcibly. if you have not already don't forget the importance of making sure the connections under the hood are clean. Corrosion is a big problem, You may seen green corrosion on a plug end, it often will creep up a wire. Take pics of anything that looks like that so we can see. We are depending on you to be the eyes and ears. its very hard to diagnose things remotely with out using your senses (no OBD with these old cars). Thanks Dave, all of my engine bay connectors are green so that may be part of the issue. I’ll document them as best I can and post the results Link to comment https://www.classiczcars.com/forums/topic/62337-78-280z-idle-problem/?&page=7#findComment-578585 Share on other sites More sharing options...
June 28, 20196 yr Author comment_578588 Link to comment https://www.classiczcars.com/forums/topic/62337-78-280z-idle-problem/?&page=7#findComment-578588 Share on other sites More sharing options...
June 28, 20196 yr comment_578595 Yep, start with cleaning those up. Use some fine sandpaper like 220 grit, rolled into flat, or better still some paint gun spiral brushes, some deoxit, and clean clean clean both the male and female parts of all those connectors. Don't forget bullets on the thermotime and CTS sub harness. You really should replace them, but for now a cleaning will suffice to at least resolve the issues. the dried up rubber seals will just let them corrode again soon. there are kits you can buy that will replace the connectors, you needs some solder skills and be sure to do neat work with proper solder technique. Edited June 28, 20196 yr by Dave WM Link to comment https://www.classiczcars.com/forums/topic/62337-78-280z-idle-problem/?&page=7#findComment-578595 Share on other sites More sharing options...
June 28, 20196 yr Author comment_578606 48 minutes ago, Dave WM said: Yep, start with cleaning those up. Use some fine sandpaper like 220 grit, rolled into flat, or better still some paint gun spiral brushes, some deoxit, and clean clean clean both the male and female parts of all those connectors. Don't forget bullets on the thermotime and CTS sub harness. You really should replace them, but for now a cleaning will suffice to at least resolve the issues. the dried up rubber seals will just let them corrode again soon. there are kits you can buy that will replace the connectors, you needs some solder skills and be sure to do neat work with proper solder technique. Oh man those used to be rubber? Haha thanks Dave I’ll give it a shot and tell ya how it turns out, most of those were fuel injector connectors so hopefully that’s why they’re staying open too long. I bought some di electric cleaner so hopefully that’ll help with cleaning them up Link to comment https://www.classiczcars.com/forums/topic/62337-78-280z-idle-problem/?&page=7#findComment-578606 Share on other sites More sharing options...
June 29, 20196 yr comment_578609 54 minutes ago, Jack Pearcy said: Oh man those used to be rubber? Haha thanks Dave I’ll give it a shot and tell ya how it turns out, most of those were fuel injector connectors so hopefully that’s why they’re staying open too long. I bought some di electric cleaner so hopefully that’ll help with cleaning them up the FI's are prob ok, as long as they are clicking. the problem will be on the CTS, corrosion equals resistance, resistance in that circuit increases on time for the injectors. I still bet you get an open reading (infinite resistance). Link to comment https://www.classiczcars.com/forums/topic/62337-78-280z-idle-problem/?&page=7#findComment-578609 Share on other sites More sharing options...
June 29, 20196 yr comment_578613 Those look like the Capitol's Dome. Link to comment https://www.classiczcars.com/forums/topic/62337-78-280z-idle-problem/?&page=7#findComment-578613 Share on other sites More sharing options...
June 29, 20196 yr Author comment_578636 4 hours ago, Dave WM said: the FI's are prob ok, as long as they are clicking. the problem will be on the CTS, corrosion equals resistance, resistance in that circuit increases on time for the injectors. I still bet you get an open reading (infinite resistance). Actually I neglected to mention that’s I already replaced the CTS connector because I tried to disconnect it once and the wires tore clean off of it so I went to autozone and bought a new one. I haven’t had the chance to run any electrical tests yet I had to take off right after I took those pictures, I’ll try and find a spare moment tomorrow and I’ll post my findings Link to comment https://www.classiczcars.com/forums/topic/62337-78-280z-idle-problem/?&page=7#findComment-578636 Share on other sites More sharing options...
