What's the preferred way of mounting the rear bar, ie, with the bar going behind the diff vs the way they were mounted from the factory, with the mounts up front?
My '71 came with an ST kit, mounted with the bar going forward, not behind the diff, if it'll fit, I wouldn't mind putting those bars in my 280 if they'll fit. I expect the front bar would, rear bar *might* since the mounting looks similar.
The stock 280 bar is too long to fit behind the diff (AZC moustache bar mount) and must be mounted from the front.
Therefore, one that was a rear mount will be too short to mount on the 280 from the front.
However, the ST sway should bolt up behind the diff of a 280 with a mounting kit no problem.
  • 1 year later...
I need some clues on torque setting for 240Z front anti-sway bar reinstall.
I had to have re-enforcing done on the right side sub frame due to cracking.
Can some one point me to a resource ?
ZDisease
