Skip to content
Sumitomo MK63 pads?
I have Sumitomo calipers on my 280 and they need replacing. The auto parts guys are drawing a blank. Where else can I get a set? Other than Japan for 200 bucks. I tried 79 Toyota 4x4 but too short. These MK63s have those weird 'ears' sticking out the sides.
This link might be helpful as a start, you can dig up the catalog with the dimensions.  I've seen where people have drilled their own hanger holes, can't remember why.  I think it was a similar situation to yours.  Long as they're hanging in the right spot and the contact points between pad and caliper meet, you can probably make something work.
https://www.bendix.com.au/sites/default/files/news-uploads/measuring_a_brake_pad_technical_bulletin.pdf
@JLPurcell
Might be able to make some recommendations. I believe he has a similar setup
Looking for calipers or brake pads for the MK63's? I have an extra set that I believe that I will hold on to, but they are out there. There are two different configurations, I believe that there is a difference in the pads for the MK63 calipers for the vented rotors as apposed to the pads for the non-vented MK63 calipers. Kats would be my go to guy for information on these calipers and pads. I know there are companies out there that will replace the brake material on your backing plates as an alternative. http://www.remaninc.com/aboutbrakepads
https://jdm-car-parts.com/collections/skyline-1969-72/products/reproduction-mk63-front-brake-pad-set-for-skyline-hakosuka
https://global.rakuten.com/en/store/parts/item/aa71-f8f010-2/
https://buyee.jp/item/yahoo/auction/j448607503
https://buyee.jp/item/yahoo/auction/j448607499
You didn't at Kat.  @Kat
Edit - is it Kat or Kats?  I could only find a Kat.
edit 2 -  alphabetical...  Too many kat before  @kats
Edited by Zed Head
Have you been drinking? That post made no sense to me. You didn't at Kat.
I had a look at those links and the Japanese bid site has the right pads for $90. Not a bad price, I guess. I still don't know who Kat is. LOL
Personally I'd go for The Real Thing when it comes to brake parts, and fit genuine Sumitomo MK63 pads.
However, there's an OEM Ford fitment that uses a similarly shaped pad to the solid rotor MK63, and they will work with a little modification. I don't know what your local market part number will be, but there's a Ferodo-branded DS2500 compound reference part number of FCP167H. Maybe you can cross-reference?
Kats is a forum member who lives in Japan and is very familiar with what was available on a wide range of Datsun models. He also owns some beautiful and rare cars...
I'd like to fit the real pads too. I just can't believe how hard they are to find in North America. Somebody must have em somewhere.
I can probably get these ones relined with new friction material cheaper than Japanese ones and have em back right away. I just thought how hard could it be. They're just pads. Not realizing how rare they are.
