June 27, 20178 yr comment_524242 Try 15btdc with max ~ 36degerees Link to comment https://www.classiczcars.com/forums/topic/57947-fuel-mixture-or-jet-adjustment-nut-settings/?&page=6#findComment-524242 Share on other sites More sharing options...
June 28, 20178 yr Author comment_524306 okay i thought that for this type of camshaft the recomendable idle timing was 12 BTDC and no more than that! Now i remember that when i bought the car the previous owner had a twice pipe installed and a FAR 311 race cam and it didnt pop on or backfire on deceleration! Just the straight twice pipe kit period and no popping whatsover! THis takes the reduced back pressure cause out of the list! http://www.thezstore.com/page/TZS/PROD/classic19i/15-6031 Anyone??? Link to comment https://www.classiczcars.com/forums/topic/57947-fuel-mixture-or-jet-adjustment-nut-settings/?&page=6#findComment-524306 Share on other sites More sharing options...
October 20, 20177 yr Author comment_532840 Well i thought there could be some opinión now that i have provided this last fact to the case in hand. Why didnt i had deceleration backfire when i reléased the gas pedal in 2nd and 3rd gear when the car had the MSA twice pipe system installed by PO: http://www.thezstore.com/page/TZS/PROD/classic19i/15-6031 Now that i took it all away and installed the MSA PREMIUM EXHAUST kit for Stock manifold, i do experience backfire on deleceration: http://www.thezstore.com/page/TZS/PROD/classic19j/15-6302 Is it due to: 1. The type of material of the pipes of the  MSA Premium exhaust is aluminum. Twice pipe is Steel. 2. MSA Premium is 2.5 inches diameter all the way. Twice pipes  features a 2 1/2" inlet that splits into twin pipes measuring a little under 1 3/4" (from the head pipe back) that terminate with two glass-pack mufflers and a pair of 2 1/2" diameter chrome tips. I don´t think that my Schneider 274F camshaft is the reason as PO had a Far 311 Race cam installed and it never popped under deceleration at any gear. Link to comment https://www.classiczcars.com/forums/topic/57947-fuel-mixture-or-jet-adjustment-nut-settings/?&page=6#findComment-532840 Share on other sites More sharing options...
October 20, 20177 yr comment_532847 Typically what sets off the excess fuel in the exhaust is a hot point. If you have a thin piece of metal in the new exhaust that gets really hot, it might even glow, it will ignite the extra fuel like a spark plug would. Link to comment https://www.classiczcars.com/forums/topic/57947-fuel-mixture-or-jet-adjustment-nut-settings/?&page=6#findComment-532847 Share on other sites More sharing options...
October 28, 20177 yr comment_533478 I have a color tune and had the same problem with checking the color reading would not change when turning the mixture nuts. turns out I had a dirty fuel filter ,car drove fine but it effected the final adjustments. it screw up the color tune reading so I changed the filter and all is good .now when I turn the mixture nuts the color tune plug changes with the adjustment . Link to comment https://www.classiczcars.com/forums/topic/57947-fuel-mixture-or-jet-adjustment-nut-settings/?&page=6#findComment-533478 Share on other sites More sharing options...
November 13, 20177 yr Author comment_534726 it only backfires on the exhaust when releasing the gas pedal on 1st and 2nd gear. If this exhaust is providing me 6hp more comparing with the stock exhaust, i think i can live with the popping on deceleration. Link to comment https://www.classiczcars.com/forums/topic/57947-fuel-mixture-or-jet-adjustment-nut-settings/?&page=6#findComment-534726 Share on other sites More sharing options...
November 13, 20177 yr comment_534750 It’s the lack of backpressure with the new exhaust. Stick some steel wool in the exhaust tip and the popping will most likely go away until it falls out. You’ll also loose you HP gain by limiting the free flowing of the exhaust. As many other members have Pointed out, a 40+ year old car is not going to perform like a modern car!!Sent from my iPhone using Classic Zcar Club mobile Link to comment https://www.classiczcars.com/forums/topic/57947-fuel-mixture-or-jet-adjustment-nut-settings/?&page=6#findComment-534750 Share on other sites More sharing options...
November 13, 20177 yr Author comment_534777 4 hours ago, Jarvo2 said: It’s the lack of backpressure with the new exhaust. Stick some steel wool in the exhaust tip and the popping will most likely go away until it falls out. You’ll also loose you HP gain by limiting the free flowing of the exhaust. As many other members have Pointed out, a 40+ year old car is not going to perform like a modern car!! Sent from my iPhone using Classic Zcar Club mobile How many horses have i gained with this MSA PREMIUM EXHAUST FOR STOCK MANIFOLD? Link to comment https://www.classiczcars.com/forums/topic/57947-fuel-mixture-or-jet-adjustment-nut-settings/?&page=6#findComment-534777 Share on other sites More sharing options...
