Site will be going down for maintenance today
Hi All,
I'm starting this thread to share a few early S30 1969 parts that I know for certain as well as some unknown parts that came with the car. I need your help to identify.
I am in KATS mode :)
Very Early Seat Belt Hook?
KATS mentioned a rubber coated steel hook.  I think this may be it.  It came mixed with a pile of nuts and bolts and plastic bits.
I could only find one,
Unknown bent wing nuts?  Junk or early part?  I was thinking air filter but they are not like the ones I spun on HLS30-00013 when Mark gave me the privilege to help him at ZCON in 2013.
Help!
I don't recognize them as a Z part. Never seen wing nuts like them either. Could it have been some sort of flange nut before the distortion?  The bends don't look uniform at all. What is the small round? protrusion on the left pic, left side in the middle?
Red dot mirror.  I thought the red dot was on the wide face, not the narrow.  Seat belt hook, yep.  Screws to the side of the seat with a chrome screw and transparent plastic washer.  I don't recognize the wing nut.
The Crab Assembly????  AC?  Heater Motor Control?   Looks like someone repaired it and closed it shut with a soldering iron.
Two conductors so  "the crab" is in series and seems to have a heat sink need.... the crab grill.
26 minutes ago, Blue said:
Unknown plastic piece
Me thinks this is a speaker guard.  Why a speaker may need a guard is another question...
