May 28, 20169 yr comment_495850 Sweaty, it's very nice work you are doing, your giving me some ideas, but I gotta say, inline fuses? Maybe its just me but I always think of inline fuses as a stop gap measure until I can address it properly. You'll never get a better chance to make it right than now. Maybe a small pony fuse panel near by on the upper kick wear the horn relay was. Love those reset beakers. Chris Link to comment https://www.classiczcars.com/forums/topic/52787-sweatys-rebuild/?&page=9#findComment-495850 Share on other sites More sharing options...
May 29, 20169 yr Author comment_495894 22 hours ago, rossiz said: do they just cool down and reset themselves - if so, will they keep blowing/resetting if you have a short? yes Link to comment https://www.classiczcars.com/forums/topic/52787-sweatys-rebuild/?&page=9#findComment-495894 Share on other sites More sharing options...
May 29, 20169 yr Author comment_495895 16 hours ago, grannyknot said: Sweaty, it's very nice work you are doing, your giving me some ideas, but I gotta say, inline fuses? Maybe its just me but I always think of inline fuses as a stop gap measure until I can address it properly. You'll never get a better chance to make it right than now. Maybe a small pony fuse panel near by on the upper kick wear the horn relay was. Love those reset beakers. Chris the inline fuse is, i think, the best solution since there is no fuse in the main panel except for the headlights, which in turn feeds the parking-tail lights. i could have added another small fuse block but that would put it up under the dash, which is something im trying to avoid. to me, these do what i need, are easily accessible and they have this cool little light that comes on if the fuse blows. Link to comment https://www.classiczcars.com/forums/topic/52787-sweatys-rebuild/?&page=9#findComment-495895 Share on other sites More sharing options...
May 29, 20169 yr Author comment_495896 22 hours ago, jwtaylor said: The some types of black electrical tape adhesive will turn to a nasty sticky goo when exposed to some types of wire insulation, oils and heat. It may not be a problem here but I have had to repair and clean up that sticky mess before, not fun. Quality tape is worth the cost. i agree. i was able to find good tape locally, but the type the factory uses i would have to order on-line. seems like everything is going that way. order it, pay shipping and then wait. hopefully, i never have to dig into this harness and deal with that stick mess. Link to comment https://www.classiczcars.com/forums/topic/52787-sweatys-rebuild/?&page=9#findComment-495896 Share on other sites More sharing options...
May 29, 20169 yr comment_495897 I've found Scotch brand at Lowes hardware to be the best around here. It's not too stretchy when you go to tear it after wrapping. It cost a good bit more than the "logs" of tape but it comes in it's own plastic case which I use for electrical crimp fittings in my bag of electrical stuff. Link to comment https://www.classiczcars.com/forums/topic/52787-sweatys-rebuild/?&page=9#findComment-495897 Share on other sites More sharing options...
June 11, 20169 yr Author comment_496713 i finally found a dash, so i now have all the dash wiring done. i ended up with 2 connectors near the left fresh air vent with a total of 9 wires feeding the gauges and lights. the only other connector is for the heater. Edited June 11, 20169 yr by sweatybetty Link to comment https://www.classiczcars.com/forums/topic/52787-sweatys-rebuild/?&page=9#findComment-496713 Share on other sites More sharing options...
July 24, 20169 yr Author comment_499418 i got a little side-tracked about since my last post. i decided to spend a day cleaning the shop after the cold weather was over. that led to a 4 week project. all of this stuff was in the way, so adding on 12x20' to the back of the shop gave me some working room Link to comment https://www.classiczcars.com/forums/topic/52787-sweatys-rebuild/?&page=9#findComment-499418 Share on other sites More sharing options...
July 24, 20169 yr Author comment_499419 10 steps forward, 5 steps back. ive been powder-coating all the door parts and trying to get everything ready for weatherstripping. for some reason, the right hand door would not line up correctly no matter what i did. it turns out that the door was 1/8" longer than the drivers door. so..........5 steps back. all after spending the past week and a half buffing and polishing. this door lines up perfectly with no shims. the other had 4 and was still off Edited August 8, 20168 yr by sweatybetty Link to comment https://www.classiczcars.com/forums/topic/52787-sweatys-rebuild/?&page=9#findComment-499419 Share on other sites More sharing options...
August 8, 20168 yr Author comment_500467 things are finally starting to click. got the weatherstripping kit and have the 1/4 windows in also got the headliner and pillars done and the dash with all the wiring hooked up. a couple of minor glitches, but everything is working now Link to comment https://www.classiczcars.com/forums/topic/52787-sweatys-rebuild/?&page=9#findComment-500467 Share on other sites More sharing options...
August 8, 20168 yr Author comment_500471 this car didnt have much of the weatherstipping when i bought it, so im not exactly sure where all the new parts go. is this the correct spot for the hood-to cowl? and does this go at the back of the door between the window channel and door? thanks all sb Link to comment https://www.classiczcars.com/forums/topic/52787-sweatys-rebuild/?&page=9#findComment-500471 Share on other sites More sharing options...
August 8, 20168 yr comment_500472 10 minutes ago, sweatybetty said: this car didnt have much of the weatherstipping when i bought it, so im not exactly sure where all the new parts go. is this the correct spot for the hood-to cowl? and does this go at the back of the door between the window channel and door? thanks all sb That's a "yes" to both. Looking really good! Link to comment https://www.classiczcars.com/forums/topic/52787-sweatys-rebuild/?&page=9#findComment-500472 Share on other sites More sharing options...
August 14, 20168 yr Author comment_500919 things are moving along nicely now new tunes. this deck is like brand new. $75 found a new windshield, Jeff from Novus Glass came out today, $227 installed, i had the new gasket. i highly recommend Novus, great people! steering wheel re-finished front dash trim painted and in after glass. this was kind of a PITA new mirrors came friday!!! got the door glass and new weatherstripping in today. all the bolts are powder-coated black. i like the black against the red more weatherstripping Edited August 14, 20168 yr by sweatybetty Link to comment https://www.classiczcars.com/forums/topic/52787-sweatys-rebuild/?&page=9#findComment-500919 Share on other sites More sharing options...
