ok guys gonna be a bit of a long post but here we go..
My Z has started to run extremely rough, whenever it gets up to running temp it will start to sputter and backfire from take off and will also seem to die out but suddenly come to life after the backfire and take off. The only thing I have been able to tell is that it only happens when the temperature outside is hot because in the mornings when I go to work the car will drive perfectly. I was talking to a friend about the issue and showed him what it was doing and he mentioned that a vehicle of his had done the same thing and he replaced the ignition control module and it solved the issue but I wanted to see if there where any other possibilities out there.
thanks.
https://www.classiczcars.com/forums/topic/51901-stumped/
280's aren't my forte'. My first guess wouldn't be ignition, sensor or fuel pressure. Start in FSM and work methodically through it. Do you have a fuel pressure gauge and a multi meter?
https://www.classiczcars.com/forums/topic/51901-stumped/#findComment-474137
I have run a fuel pressure test on it and everything was alright. It was a little while ago so I don't remember the exact results. I guess I should have mentioned that my car had begun to do this towards the end of last summer and as the temp outside lowered the problem went away and I got caught with other issues and this one slipped my mind.
https://www.classiczcars.com/forums/topic/51901-stumped/#findComment-474138
Your friend's suggestion was a good one.  But you kind of have a mix of symptoms with "come to life after the backfire and take off. The only thing I have been able to tell is that it only happens when the temperature outside is hot because in the mornings when I go to work the car will drive perfectly. "  Usually the modules stay screwed up until the engine is turned off for a short time.  I had one that worked fine until I revved the engine over about 3000 RPM.  Then it would run rough until I turned it off and restarted.
One clue about the module is the tachometer needle.  It won't read correctly, usually high, and the needle will jump around.
One test of the module that apparently works well is to spray it with a cooling spray.  You can buy them in various stores, I've heard.  When things are bad, spray the module and see if it goes away.  Here's an example, I don't really know where to get it.
http://www.amazon.com/Professional-Freeze-Electronic-Component-FR-777-777/dp/B000Z99ZCA
You can also wire in a GM HEI module, permanently or just for a test if you get frustrated.  They're about $20, and actually perfrom just as well as the expensive Nissan replacements.
https://www.classiczcars.com/forums/topic/51901-stumped/#findComment-474141
Thank you for the help. My tachometer does actually jump or it will just stick in place and wont work right again till I shut it off and wont work right till it has slowly settled back to zero. I didn't realize that the ICM could effect that, but now that I think of it, it makes sense.
Edited by 78blackpearlz
https://www.classiczcars.com/forums/topic/51901-stumped/#findComment-474157
Alright guys I pretty much just said screw it and went ahead and ordered a new ICM since it seems to fit the best. It should be here Friday hopefully, I'll post the results as soon as i can. Thanks again guys for the help.
https://www.classiczcars.com/forums/topic/51901-stumped/#findComment-474168
You must be wanting to keep everything "stock"? ZedHead had a good solution to an expensive part in his post (number 5). Would have saved you a lot of money. Everyone that has done the switch is happy with the results. I'm just waiting for mine to go so I can try it.
Plus I'm just realizing you said a "new" ICM. Did you actually find a new one? I was under the impression new ones are long gone.
https://www.classiczcars.com/forums/topic/51901-stumped/#findComment-474180
Sometimes the money-time-knowledge calculations just point to replace and hope.  I had meant to add a reply about the tachometers in these old cars commonly getting stuck high when they get hot.  It's usually a smooth problem though.  The jumpy needle from the module pumping out too many sparks is pretty dramatic though.  It's scary.
https://www.classiczcars.com/forums/topic/51901-stumped/#findComment-474212
Yea I am trying my best to keep everything as stock as possible which is proving to be a bit of a challenge. But I did find a new one its not an OEM part because they don't manufacture them anymore. I got lucky and found one on rockauto for $120 when everywhere else wants $200+ for them. I read a lot about the HEI "conversion" with it and just decided for some reason to go with the ICM. And I'm hoping this isn't to much of a "plug and play" since my z is a daily driver and it gets a little hairy at times with this one.
https://www.classiczcars.com/forums/topic/51901-stumped/#findComment-474233
