July 19, 20205 yr Author comment_603093 Okay, thanks. I’ll find this and mount it and see if this vapor pipe mates up to it. However, I was planning to delete my emissions control devices, so not sure what to do now. Edited July 19, 20205 yr by Matthew Abate Link to comment https://www.classiczcars.com/forums/topic/51541-1973-rebuild/?&page=74#findComment-603093 Share on other sites More sharing options...
July 20, 20205 yr comment_603112 12 hours ago, Matthew Abate said: Okay, thanks. I’ll find this and mount it and see if this vapor pipe mates up to it. However, I was planning to delete my emissions control devices, so not sure what to do now. I understand - I have that equpiment off my car as well. This bit of plumbing is entirely passive and uses the air flow thru the air filter box to pull excess fuel tank and crankcase vapors so they can be burnt. The connection between the valve and the pipe is a 3-4" piece of hose usually secured with a couple of spring clamps. Link to comment https://www.classiczcars.com/forums/topic/51541-1973-rebuild/?&page=74#findComment-603112 Share on other sites More sharing options...
August 2, 20205 yr Author comment_603640 On 7/20/2020 at 8:49 AM, jfa.series1 said: I understand - I have that equpiment off my car as well. This bit of plumbing is entirely passive and uses the air flow thru the air filter box to pull excess fuel tank and crankcase vapors so they can be burnt. The connection between the valve and the pipe is a 3-4" piece of hose usually secured with a couple of spring clamps. Any chance you can post a few photos of how this vapor line is secured to the engine bay? I’m trying to figure out how to rout it through all of the insulator clamps that hold it onto the car. I found this build log that has some usable photos, but the vapor return line is significantly different from mine. I’m thinking these Classic Tube lines have some incorrect bends, or they are at least twisted. Edited August 2, 20205 yr by Matthew Abate Link to comment https://www.classiczcars.com/forums/topic/51541-1973-rebuild/?&page=74#findComment-603640 Share on other sites More sharing options...
August 2, 20205 yr comment_603663 Matt, I think this should meet your need. The vapor line gets connected to the vapor valve with a short length of hose, not yet installed in this pic. The vapor valve is just below the ballast resistor. FYI - the not-stock item below the vapor valve is a compressor for air horns. Let me know if any questions. Jim Link to comment https://www.classiczcars.com/forums/topic/51541-1973-rebuild/?&page=74#findComment-603663 Share on other sites More sharing options...
August 2, 20205 yr Author comment_603665 Thanks, Jim. Yeah. My vapor line is substantially different. I bought the one for the ‘73 and didn’t realize I wouldn’t be able to figure it out. There are some hard to see but usable photos here that will help. I think I need to get the brake lines in before I continue with the fuel lines, plus it looks like I have a few things wrong with how it’s mounted right now. Edited August 2, 20205 yr by Matthew Abate Link to comment https://www.classiczcars.com/forums/topic/51541-1973-rebuild/?&page=74#findComment-603665 Share on other sites More sharing options...
August 16, 20204 yr Author comment_604296 Okay. Got the four main lines in The tunnel tonight. I had to mess with these Classic Tube lines quite a bit to get them in, and I’m a little unsure about how they are in the back, but I’ll leave the Dif out for now in case I need to mess with them more. the main issue is the vapor and main fuel lines are a bit long and the fuel line was missing a few bends in the middle for the trans mount support and had an extra two bends in the back, at least as compared to my old lines. whatever. They’re in. Now on to the rear brake lines. Link to comment https://www.classiczcars.com/forums/topic/51541-1973-rebuild/?&page=74#findComment-604296 Share on other sites More sharing options...
August 27, 20204 yr Author comment_604912 I woke up this morning and had a flash of a realization that I am wasting my time cleaning up my proportioning valve because I am putting discs on the back, so I need to put an adjustable proportioning valve on the car. Naturally I have a bunch of questions as a result. First, is there a Nissan adjustable proportioning valve out there? It seems that everyone is using the small Willwood one. Second, is this larger Willwood valve actually meant to replace the distribution block (middle in the photo below)? I have read here that this should be kept factory original. Third, I have a '73 made in July, which has the proportioning valve in the engine bay (bottom in the photo below), 280z style, and the small t-block (top in the photo below) that will be left alone. These are my parts: I’m thinking of going with a valve from Tilton because it has 10mm ports and I won’t need adapters. Anyone have any comments? It’s not super pretty but I’m concerned about failure at unnecessary connections. Edited August 27, 20204 yr by Matthew Abate Link to comment https://www.classiczcars.com/forums/topic/51541-1973-rebuild/?&page=74#findComment-604912 Share on other sites More sharing options...
September 16, 20204 yr Author comment_606035 Cleaned up some parts. Link to comment https://www.classiczcars.com/forums/topic/51541-1973-rebuild/?&page=74#findComment-606035 Share on other sites More sharing options...
September 17, 20204 yr comment_606083 Great photos guys! Link to comment https://www.classiczcars.com/forums/topic/51541-1973-rebuild/?&page=74#findComment-606083 Share on other sites More sharing options...
September 17, 20204 yr comment_606112 I encountered the same issue when I changed to a big brake kit from Arizona Z car including the change to discs on the rear. In my opinion the Wilwood prop valve is big and clunky and I wanted something more compact that ideally could be installed in the same position as the OEM fixed prop valve. So I ended up using this: https://www.speedwaymotors.com/Speedway-Compact-Adjustable-Brake-Proportioning-Valve,1979.html It's really small and adjustable but does require conversion fittings to adapt to metric lines. Alternatively you could change the fittings on the lines themselves to match the threads on the prop valve. I ended up having to make a new line from the splitter to the prop valve as the original one was a little short and I had to devise a way to mount it to the firewall in the same OEM location, but it all worked out. Here's a few pictures of my install. The valve works great and I have it adjusted so I get an optimal bias between the fronts and rears. Hope this helps. Link to comment https://www.classiczcars.com/forums/topic/51541-1973-rebuild/?&page=74#findComment-606112 Share on other sites More sharing options...
September 23, 20204 yr Author comment_606464 I might just have to send my willwood valve back and pick that up. Question about the adapters: are they IFF or concave usually? I was going to call classic tube to find out but was on hold forever. and how did you mount it? Edited September 23, 20204 yr by Matthew Abate Link to comment https://www.classiczcars.com/forums/topic/51541-1973-rebuild/?&page=74#findComment-606464 Share on other sites More sharing options...
September 23, 20204 yr comment_606468 The threads on the valve itself are 1/8 NPT. You would either need to get an adapter that converts that to the metric fittings on the Z lines or remake the lines with the appropriate fittings. They actually sell a version with SAE adapters included. You can find it here: https://www.speedwaymotors.com/Speedway-Motors-Brake-Proportioning-Valve-Kit-With-Fittings,387281.html As far as mounting it, I attached a 1/8 inch aluminum "plate" to the side of the valve and drilled and tapped a hole in that plate. I then used a small right angle bracket that attaches to the valve in the new tapped hole and the other side of the right angle bracket goes into the original tapped hole on the firewall that used to hold the OEM valve. You can see the "plate" that I added in the last picture that I posted above. Hope that helps. Mike. Link to comment https://www.classiczcars.com/forums/topic/51541-1973-rebuild/?&page=74#findComment-606468 Share on other sites More sharing options...
