Posted May 14, 201510 yr comment_469800 I have been looking for some touch-up paint to use in the engine bay of my 918 orange '70 240z and I found a company called ColorRite that supplies touch-up paint in aerosols, half pints and pens in a few of our colors. Here is a link to their site and a link to an amazon example: http://www.expresspaint.com/automotivetouchup/pc/viewPrd.asp?idProduct=17516&idCategory=24&resetSess=Y#details http://www.amazon.com/ColorRite-Aerosol-Nissan-Automotive-Touch-up/dp/B00GVOBDIM/ref=au_as_r?_encoding=UTF8&Make=Nissan|67&Model=240Z|2284&Year=1970|1970&ie=UTF8&n=15684181&s=automotive&vehicleId=2&vehicleType=automotive Anyone have any experience with this company and if so how would you rate their products. If you know of other touch-paint suppliers for our old paint codes please add to this thread with supplier names and reviews if possible. Mike Link to comment https://www.classiczcars.com/forums/topic/51485-touch-up-paint-sources-opinions/ Share on other sites More sharing options...
May 14, 201510 yr comment_469805 I recently worked with the folks at PaintScratch.com for touch-up on my 920 Safari Gold. It was not previously in their available set but they quickly researched it, found the formula, and added it their standard offerings. It was a great match! Check them out. Edit: they're using a PPG formulation. http://www.paintscratch.com/ Edited May 14, 201510 yr by jfa.series1 Link to comment https://www.classiczcars.com/forums/topic/51485-touch-up-paint-sources-opinions/#findComment-469805 Share on other sites More sharing options...
May 14, 201510 yr comment_469806 I've used http://www.automotivetouchup.com/touch-up-paint/datsun/ with some success for inside the engine compartment of my 1973 Avocado Metallic 240z. Link to comment https://www.classiczcars.com/forums/topic/51485-touch-up-paint-sources-opinions/#findComment-469806 Share on other sites More sharing options...
May 15, 201510 yr comment_469839 I'm happy with some touch-up paint I bought from Jeff's Paint at amazon.com. Â Small amount for scratches blended in very good after I had the original paint wheeled out to a new shine. Â I called him though, he sent me #918. Â His listings didn't show '72 240Z. Link to comment https://www.classiczcars.com/forums/topic/51485-touch-up-paint-sources-opinions/#findComment-469839 Share on other sites More sharing options...
May 15, 201510 yr Author comment_469850 Thanks to Jim, Sean and site for your suggestions, I will check them out. Link to comment https://www.classiczcars.com/forums/topic/51485-touch-up-paint-sources-opinions/#findComment-469850 Share on other sites More sharing options...
