June 20, 201510 yr comment_472395 I was more curious than anything, it seem to be negelected.I have used diodes in the past to reduce the back emf. Don't know if they still call it that these days. I know diodes are less reliable, but I have never had one fail on me yet.Maybe I should have said "normal" instead of "servicable" relay since most relays don't have this voltage spike limiting function.I believe the resistor is between 600 - 800 ohm which wouln't draw much anyway. Link to comment https://www.classiczcars.com/forums/topic/50416-75-280z-headlight-relay-upgrade/?&page=6#findComment-472395 Share on other sites More sharing options...
June 21, 201510 yr comment_472409 Back EMF works for me as well. I've heard it called lots of different things. Whatever works! Link to comment https://www.classiczcars.com/forums/topic/50416-75-280z-headlight-relay-upgrade/?&page=6#findComment-472409 Share on other sites More sharing options...
July 7, 20159 yr comment_473363 If you just wanted to install a couple pigtails for the relay control now, but will be adding the relays in later, where would be a good place to put those in? Edited July 7, 20159 yr by TomoHawk Link to comment https://www.classiczcars.com/forums/topic/50416-75-280z-headlight-relay-upgrade/?&page=6#findComment-473363 Share on other sites More sharing options...
July 8, 20159 yr comment_473425 TomoHawk, Not sure what you're asking... What do you mean with the above? I'm probably just dense, but can you ask your question a different way? Link to comment https://www.classiczcars.com/forums/topic/50416-75-280z-headlight-relay-upgrade/?&page=6#findComment-473425 Share on other sites More sharing options...
July 9, 20159 yr comment_473456 If you wanted to add fog lamps or driving lamps, which should only come on with the headlights, you need two switched +12V lies from the headlamp switch to power some relays. where would a good place to get the switch +12V? You would put in one or two extra wires that would operate the relays for the extra lamps. Link to comment https://www.classiczcars.com/forums/topic/50416-75-280z-headlight-relay-upgrade/?&page=6#findComment-473456 Share on other sites More sharing options...
January 29, 20169 yr comment_485614 I'm following this old thread and wonder if anyone of you ever attempted to modernize the bulky resistors in a modern car relay box as you did with the headlight relays? Â Â Link to comment https://www.classiczcars.com/forums/topic/50416-75-280z-headlight-relay-upgrade/?&page=6#findComment-485614 Share on other sites More sharing options...
January 29, 20169 yr comment_485615 Location of these resistors are behind the fusible links on the right hand side of the engine bay. Link to comment https://www.classiczcars.com/forums/topic/50416-75-280z-headlight-relay-upgrade/?&page=6#findComment-485615 Share on other sites More sharing options...
January 29, 20169 yr comment_485616 Those are relays, not resistors, and they aren't that bulky compared to standard automotive relays. Link to comment https://www.classiczcars.com/forums/topic/50416-75-280z-headlight-relay-upgrade/?&page=6#findComment-485616 Share on other sites More sharing options...
January 29, 20169 yr Author comment_485623 ryn004, What's the purpose for? Is there any advantage? Adding headlight relay close to battery will increase  brightness of headlight. Same to starter relay. But, I don't see any advantage to re-wiring fuel pump, EFI relay. Link to comment https://www.classiczcars.com/forums/topic/50416-75-280z-headlight-relay-upgrade/?&page=6#findComment-485623 Share on other sites More sharing options...
January 29, 20169 yr comment_485625 Because having everything in one place is more convenient and tidy like in my Impreza. Link to comment https://www.classiczcars.com/forums/topic/50416-75-280z-headlight-relay-upgrade/?&page=6#findComment-485625 Share on other sites More sharing options...
January 29, 20169 yr comment_485627 Are you talking about re-wiring your car to move those relays elsewhere? Link to comment https://www.classiczcars.com/forums/topic/50416-75-280z-headlight-relay-upgrade/?&page=6#findComment-485627 Share on other sites More sharing options...
January 29, 20169 yr comment_485628 Same place just want to revamp the marked area in the photo. (Photo is for illustration purposes and not mine) Link to comment https://www.classiczcars.com/forums/topic/50416-75-280z-headlight-relay-upgrade/?&page=6#findComment-485628 Share on other sites More sharing options...
