New guy here so please be kind. Just got a 79 280zx for FREE. I noticed it has a crack all the way through the rubber boot between the mass air flow to the throttle body. No new part available, can't find one used. I don't have much money right now but would like to buy a used rather than repairing mine. Any idea's?????:cool: Thanks Mike
The 79 and 80 share the same hose nissan P/N# 16578-p7100
Edited by tahuyaredrider
https://www.classiczcars.com/forums/topic/44750-afm-to-throttle-body-hose/
You could also give your local Nissan dealer a try.
Part no. 16578-P7100. I ordered other parts for the intake on a 280Z 1977 no problems and not to much price difference with nissanpartszone.
Goodluck searching
Goodluck searching
My local Nissan dealer says it is obsolete and no dealers across north america has this hose in stock.:disappoin
You could try the hose for the 280zx 1980 model. You will need to block the extra side hose nozzle. MSA sell them, I think.
Looks like your model is no longer stocked. Could be because it change over to the 1980 model soon after intro and therefore too little demond nowdays.
I could order mine, for a 280Z 1977 model here in the Netherland last june no problems. Thats another type again. MSA
Check MSA. They list them all, but yours is no longer available. http://www.thezstore.com/page/TZS/CTGY/SFC03A
Expensive, but available - http://www.datsunstore.com/index.php/cName/engine-4-filters-intake-air-cleaners-4
If I was in your boat I would go to Home Depot and look at plumbing adapters and vacuum hoses and cobble something together.
  • 1 year later...
You've probably found a cure for your prob, but...
I had the same problem, a torn boot. Like you, I could not find a replacement, so I "engineered" it.
I cleaned the area of the tear with acetone. I super glued as much of the tear as possible (maintaining the original shape). Then I coated the area (inside and out) with liquid rubber.
Ta-Da...it worked!!!
  • 1 month later...
Same problem here on my 79. I got it free from my dad. There were a lot of older parts that needed replacement so I just used duct tape as a temporary fix. Ended up ordering one from zcarsource.com
