Skip to content
71' Refresher project starts
First attempt to start made today!!! Fuel is good, No Spark however. :cry:
More investigation needed...
Coil is good, need more wiring write ups for MS2.
Installed new clutch slave cylinder, electric radiator fans are too small,
Working through the bends.
LOL, no driving yet but she is pretty much complete. Bled brakes and clutch, a little wiring and cleaning up done today. First time off the jackstands in a year or so. Back end is a little high but can be done later on. Waiting on radiator fans in the mail. Wiring still being worked out, but the hard labor is done. First phase done! :classic:Lots of work to do with paint and interior but it feels good to be back together.
Everything is back together again, hood, radiator, front bumper, valance, etc. Tires are too big (225s), :cry: but will fix later. Taking to a shop soon to have tuning, exhaust welded, and wiring sorted out. Very happy! :cool:
Fluids filled! New hood release and cable, battery tray, stalks, lots of little things done today. Awaits a lift to the shop.
  • 3 weeks later...
Runs! Sounds great, shop did a good job with wiring. More work ahead, some nagging issues to take care of:
- A wheel alignment, yikes!
- More tuning needed
-BMC is leaking, so will have to change out and bleed,
- Need a longer clutch slave push rod
But very happy to have an exhaust and a running Z after all the work put in getting it to this point. :D:D:D
Congrats. Its looking good in the photo and the ride height is sitting nicely. Now its time to enjoy:D
You dont see it from the outside, but you have done a hell of a lot of work on it. I bet it feels like a completly different car now.
Is the slave cylinder different on the T5? Never had a T5, so not sure if its the same.
Are you using the 15/16" BMC out of the early 280ZX? Kits are easy to get, but a complete one is not so easy these days.
Enjoy
Chas
Thanks Chas, yes tons of work and time in to it. Working on a video. Will be putting in a n/a 5spd next week with any luck .
[ATTACH=CONFIG]67564[/ATTACH]
So why are you taking out the T-5? Admittley the Nissan has better ratios but you will hate the shifter after you have been using the Mustang shifter.
Your project looks good and you are running MS2?
