Hello ,,,The P.O. removed the glove box to replace the blower. never installed a new glovebox..I took a quick look and cant see how this fits in...Is there any special thing i need to do....it does not go in from the front and cant seem to fit from the rear...this is just that cardboard box...Any tips? THANKS
https://www.classiczcars.com/forums/topic/42802-glove-box/
That is how is is done plastic or paper.
"You actually have to squish it to get it "
http://www.classiczcars.com/forums/showthread.php?25228-How-do-you-remove-the-!!-Glove-Box
https://www.classiczcars.com/forums/topic/42802-glove-box/#findComment-385862
If it is the original glove box, you may be able to fold it and get it into position from the front. If it is a new box, it will probably be very stiff and may not fold easily (potential damage here!). If new and rigid, the install will be best from the rear. The blower motor will have to come out to provide access room. Been there, done that!
Jim
https://www.classiczcars.com/forums/topic/42802-glove-box/#findComment-385911
