Do you guys know if there is a cheapest way to replace the rubber only (#8 in the attached file), before buying these parts at black dragon auto at $49.95 each. post-19642-14150817918999_thumb.jpg
Thanks. :)
I don't know if you can purchase the rubber only. I ordered the whole piece from BD and am not happy with it. The stock one is heavy gauge compared to the BD one. I will take a look at the motorsport one in April at the show. It was too easy to dimple the new one. It is thin metal.
It seems everyone is looking:
http://www.classiczcars.com/forums/showthread.php?38875-Door-Window-Squeegee&highlight=window+squeegee
I am holding off for a little while on that one, at least untill I hear good news from someone.
Thanks for the link and the info. Mine is already deteriorated and the wind noise is killing me. I guess I will try and search the junkyard and see if there are any alternative from other cars.
Here is the latest, I purchased the pieces from black dragon auto. Here is the before and after pictures. I used a black weather strip adhesive to attach them.
This took only 15 minutes to do. I will do the passenger side later when it gets nicer out.
Do you guys know if there is a cheapest way to replace the rubber only (#8 in the attached file), before buying these parts at black dragon auto at $49.95 each. [ATTACH=CONFIG]51452[/ATTACH]
Thanks. :)
This looks like rubber-only w/rivets but they're not cheap...
http://www.datsunlandsocal.com/mm5/merchant.mvc?Store_Code=DS&Screen=PROD&Category_Code=240ZWeatherSeals&Product_Code=D001
Edited by Willoughby Z
changed link
