Clean the back and look for makers mark.  Anybody like Fenton Gyros I picked up a set with good tires for 160 bucks.
I will have to get a pic up.  Also I just parted out a 79 zx it had 3 good pansports 16 x 7 I payed 450 for the car
and over 1k in parts sold I will order 1 pansport and have a nice set for free.
2 years ago I picked up some appliance mesh for 60 bucks then found some copper cobra's for 60 bucks also.
Hard to tell with 17s in there but they look great.  Those fit without any modifications?
My front tires rubbed the outer edge of the fender when I turned real tight.
The overall tire diameter is all that's relevant. The 17" wheel doesn't matter. I'd have to do check but my guess is your tires are about 1/2" under and mine are 1/2" over the original 14" equivalents.
That is absolutly correct. You can put 20 inch wheels on a 240Z if you want to.
Lumens, does that exhaust sticking out that little bit extra help with in cab fumes with the windows down?
Not one bit. But it helps to keep the bumper from rotting out on that side.
I found my exhaust fume leak but I will have to find an exhaust leak thread
to post what I found. No more fumes at all.
To answer the question, at speed a dip in the road will cause me to bump the inside of the arches. The lips clear, and have never rubbed, front or back and I havnt rolled or otherwise modified the fenders in anyway.
Also, the front a-arms are length adjustable, so they can aid in camber/track and clearance as required.
235's fit well on my car, I think 245's would be tight. That said this tire fits wide, like most 245's would.
Modifications that are relevant to this fitment are 2.5" coils on a GC suspension kit, and significant camber. If I flattened out the camber, I'm sure the rears would rub the lips.
-can't belive how I need to edit nearly every post because of Samsung's insanely poor autocorrwction. <--- I actually typed autocorrection there.
Edited by oranngetang
