Has anyone used one of these? It seems, by the nature of toilet tissue, that it would break down and clog up every passage in your engine. jlp
Wow the Franz Oil Filter!
I used this back in the 80's on my 77 Datsun pickup. I don't remember ever having a problem with it.
As I recall it was recommended to use their brand of paper as it was a lot more dense than normal t-paper. I did replace it with standard t-paper and it ran fine it didn't break down. When I did go to replace the roll, it was just a in tact oil-soaked roll of toilet paper.
Like I said...it ran fine. This was in the mid 80's.
Would I use it again? I doubt it. I wish I could offer solid evidence either way. It appears to be used extensively in the trucking industry with good results but I defer those who are better informed.
Dave Ruiz
My dad used to use a kotex (or that "type" of product) in the old chevy. Never thought a thing about it at the time. I'll have to check the old Chrysler and see if it has a roll in it. (it doesn't get driven much). I know the old Volvo uses a cartridge but a roll "can be used in an emergency". One wouldn't think the oil could get through in a timely manner and it would just go through the bypass.
I don't believe it could actually filter the oil through the roll of toilet paper.
JLP
I used them. There 50's 60's tech, yes they work, ment for cars that had no filter, no I would not want to run one now. Not even if I thought they were cool. Buy an Oberg, same idea, newer tech.
