June 21, 201015 yr Author comment_323229 So... can anyone tell me the purpose of the cut bolt and this matching "washer"? It appears to facilitate some adjustment of the transverse link but I cannot find reference to it in the workshop manual.... Link to comment https://www.classiczcars.com/forums/topic/36234-torque-setting/?&page=2#findComment-323229 Share on other sites More sharing options...
June 21, 201015 yr comment_323236 Mark:See the other post. Those bolts are not stock. This is a "clever" (other may have a different word for it...) attempt at camber adjusting me thinks. Link to comment https://www.classiczcars.com/forums/topic/36234-torque-setting/?&page=2#findComment-323236 Share on other sites More sharing options...
June 21, 201015 yr comment_323239 I have the same or similar that I have been unable to remove without damage. The washers are made of aluminum and are galled tightly onto the bolts. I think you will be able to substitute the bolt & nut with an aftermarket alternative if they are NLA.Edit: Here is a better view of the stock bolt, nut, washer and bushing (15, 16, 17, 14). Edited June 21, 201015 yr by geezer Link to comment https://www.classiczcars.com/forums/topic/36234-torque-setting/?&page=2#findComment-323239 Share on other sites More sharing options...
June 22, 201015 yr comment_323276 What you have in you car is a camber adjustment kit from Specialty Productshttp://www.spcalignment.com/PROD_DIR/SPC_PROD_SEARCH_DYN.cfm?cmd=Cam&cmd2=83115&cmd3=When I took my car in to get it aligned at Les Schwab. the guy pulled that exact kit out saying it was the oldest parts he had and was shocked that he had it at all in the first place.Check out the installation instructions, what they do with that is cut a larger hole in your front cross brace 54401-E4100. install the eccentric and adjust your camber. You can never go back, once the hole is cut the stock bolt will no longer fit. To be stock again you would need to get a new cross brace. Link to comment https://www.classiczcars.com/forums/topic/36234-torque-setting/?&page=2#findComment-323276 Share on other sites More sharing options...
June 22, 201015 yr Author comment_323281 YIKES... so what was installed was the stock bushing and this kit - that means the "insides" were not correct for the "outsides". I THINK this is really not good, dangerous even. Link to comment https://www.classiczcars.com/forums/topic/36234-torque-setting/?&page=2#findComment-323281 Share on other sites More sharing options...
June 22, 201015 yr Author comment_323288 Please, let's move this conversation over to my other thread on the subject... no more posts here.Do it here:http://www.classiczcars.com/forums/showthread.php?p=331456&posted=1#post331456Thanks... and sorry for the confusion. (and thanks for the help!) Link to comment https://www.classiczcars.com/forums/topic/36234-torque-setting/?&page=2#findComment-323288 Share on other sites More sharing options...
