Posted December 2, 200915 yr comment_301935 Which is the most practical air filter for 42DCOE's on a 2.8L 240Z?1. Individual K&N Filters (already have these so it's the easiest for me ... just need to get a heat shield)2. Air horn socks / covers. These appear to be simple metal mesh filters. Honestly these look 'cool' and would really show off the air horns. 3. Single large air filter assembly with integrated heat shield (about $200 + cost of air filter ... likely $300 total). 4. Other exotic 'cold air boxes', carbon filter, etc. These seems to be more applicable to racing than something for the street.I'm currently leaning towards the K&N, but that leaves me with a need for a decent heat shield over my ceramic coated headers. I saw a link for a JDM shield (stainless steel I believe) that was in the $150 range. Seems like something I could fabricate for far less. Link to comment https://www.classiczcars.com/forums/topic/34003-triple-weber-42-dcoe-air-filter-choice-assistance/ Share on other sites More sharing options...
December 2, 200915 yr comment_301945 Most practical is what you already have. But best choice is different. The best choice depends on your personal value set. What matters the most to you. Cost, performance, ease of use, availability, etc.I would suggest what filters the air the most efficiently to keep your engine as happy as possible. Link to comment https://www.classiczcars.com/forums/topic/34003-triple-weber-42-dcoe-air-filter-choice-assistance/#findComment-301945 Share on other sites More sharing options...
December 2, 200915 yr comment_301957 I have use separate single filters, an ITG single and now have a TWM fiberglass box with a K&N cold air set-up for my triple 44mm Mikunis.The JDM SS heat shield is a very piece for the price and I'm likely to get one myself if it's not under the tree this Christmas. I have the ITG large single filter if you like to buy it.... Link to comment https://www.classiczcars.com/forums/topic/34003-triple-weber-42-dcoe-air-filter-choice-assistance/#findComment-301957 Share on other sites More sharing options...
December 3, 200915 yr comment_301968 I had the single ITG on a triple Weber 240 I used to own (now Lazeum's car). It was big $$$ and was hard to get on and off for tuning, but from everything I read, it was supposed to be the best for performance. I think I paid close to $300 for it many years ago. I doubt I would buy that one again due to the cost and pain to R&R. Link to comment https://www.classiczcars.com/forums/topic/34003-triple-weber-42-dcoe-air-filter-choice-assistance/#findComment-301968 Share on other sites More sharing options...
December 3, 200915 yr comment_302019 Hi Jeff! The ITG is still in my garage but it has always been a pain to install/remove and to work around with it. Moreover each time, we (me & Glenn before) have to remove it, it was sliding along the brake master cylinders. the foam is no more in good shape. So I switch to 3 K&N filters. I haven't felt any difference by changing the filters and it is more practical. I think also it looks good. Link to comment https://www.classiczcars.com/forums/topic/34003-triple-weber-42-dcoe-air-filter-choice-assistance/#findComment-302019 Share on other sites More sharing options...
July 24, 201114 yr comment_362354 Lazeum, are you or can you run air horns under those filters? I have similar setup and need filters in the next week or so. If I get the K&N filters, should I remove the air horns or put them on over top of horns? My headers are wrapped with header tape and I dont have a heat shield by the way.Brian Edited July 24, 201114 yr by pjoe Link to comment https://www.classiczcars.com/forums/topic/34003-triple-weber-42-dcoe-air-filter-choice-assistance/#findComment-362354 Share on other sites More sharing options...
July 24, 201114 yr comment_362367 My set up is ideal for me..............see my garage or the below link to reviewhttp://www.classiczcars.com/forums/showthread.php?42045-Wolf-Creek-Racing-Mikuni-40-s Link to comment https://www.classiczcars.com/forums/topic/34003-triple-weber-42-dcoe-air-filter-choice-assistance/#findComment-362367 Share on other sites More sharing options...
July 25, 201114 yr comment_362374 That setup is definately cool. I want to use the horns but just dont know if it will work ok with the K&Ns. Link to comment https://www.classiczcars.com/forums/topic/34003-triple-weber-42-dcoe-air-filter-choice-assistance/#findComment-362374 Share on other sites More sharing options...
July 25, 201114 yr comment_362415 I have 40mm long or so air horns under the filters. so yes, you can fit some. I try to get a picture to show you the horns, this is the only one found from my old setup. Link to comment https://www.classiczcars.com/forums/topic/34003-triple-weber-42-dcoe-air-filter-choice-assistance/#findComment-362415 Share on other sites More sharing options...
July 25, 201114 yr comment_362419 perfect. thanks Link to comment https://www.classiczcars.com/forums/topic/34003-triple-weber-42-dcoe-air-filter-choice-assistance/#findComment-362419 Share on other sites More sharing options...
July 25, 201114 yr comment_362438 you're welcome Link to comment https://www.classiczcars.com/forums/topic/34003-triple-weber-42-dcoe-air-filter-choice-assistance/#findComment-362438 Share on other sites More sharing options...
