Skip to content
Pay it forward!!!
I believe my quarter window louvers have been claimed! :-)
Merry Christmas, all!
Peace,
Sarah
Marty,
Ashtray recv'd, repaired (decent job if i do say so myself) and now has home in my console. VERY much appreciated.
and now to keep paying it forward..........
1 set (used) visors in red. good shape, no tears, slight silver overspray looks like it can be cleaned off or left.------GIFTED
1 set poly bumpstops (new) in blue------------- GIFTED
1 set poly bushings (new) in black for rear struts------------- GIFTED
1 pass rear wheel cylinder (new) for 240z with brake hard line straight out from cylinder. My '71 had the angled brakeline and I had this one too long before i went to install to return.------------- GIFTED
1 set (used) quarter window louvers. Black plastic (ABS?) driver's side has 1 crack looks to be repairable, pass side no cracks. Slightly faded, i'd recommend a quick spray.------GIFTED
Kris, shipped today. PM sent.
Dustin, Bob and H.H., your parts are on there way. With a little luck, you might have them before Xmas.
There are a few parts left:
- '83 fan and fan clutch. clutch feels good.
- '83 thermastat housing
- '83 Pulley
- '70 Water Pump pulley cover. Great core to send in for re-plating.
- '70-71 Fan clutch. Not pretty but worked well when removed.
- Left side headlight cover. Good condition, with gasket.
Marty
Still a few parts left. Surely someone could use them.
Marty
Marty,
Tool lids and shift boot arrived.
Many Thanks,
H Houghton
My pleasure. If you haven't already, don't forget to post something for the next guy.
Marty
  • 4 months later...
I thought I'd bring this thread back to life. I'm shipping a pair of wiper arm nuts to Koalia in Finland today. He needs 'em, can't find any in Finland, and I've got spares I don't need.
And thanks for that Arne! There aint much Z's (none) in our scrapyards where to look. There's lot of other Datsuns like 100A (most popular one in 70's), 120A, 120Y, 150Y etc etc but no Z's.
Prefer local pick-up in Bakersfield, CA.
From 76 280z:
- removed used a/c parts (compressor, seized pulley, vacuum canister, brackets, some relays and vac. tubing). The box is heavy and needs to go as one unit, please. A/c was disconnected in the car when I bought it, the a/c compressor's condition is unknown. A heater core will be included.
Chevy 350 engine bare block, 4-main, I acid dipped it a few years ago, still has surface rust. 0-over if I am not mistaken. It will definitely need to be bored out.
For faster response please email me at simzealot at gmail doooootttttt com.
Den
I'll bite. I have a tired-but-working alternator and mechanical voltage regulator out of my 5/72 car. I'm sure the alternator could use a refresh, but it powered the car well enough to drive it before I swapped in a modern one. PM me if interested.
I am going to round up and send BTF/PTM a pair of good Taillight housings...
Will
  • 6 months later...
I've gone to coilovers and these springs are useless to me. What I have is the complete Tokico "kit" from MSA except for the front shocks, (they are now my rear shocks) These springs lowered my car about 7/8 inch. Four springs, (I have them marked as to front and rear) and two BZ 3016 Illumina shocks. All you need is a couple of BZ 3015 for the front and you have the whole kit that MSA sold for $499. (mine is a '71 240 Z)
Edited by WW2Winger
