My OEM antenna didn't work so this weekend I completely dis-assembled it, cleaned-up all the corrosion and "muck" on the inside and installed a new OEM antenna mast, (provided by the PO).
Installing the new antenna mast was not difficult, but the interior of the mechanism was filled with a mixture of dried-up grease & dirt. Also, the aluminum channel the nylon antenna rod runs in was very heavily corroded. Inside the motor case I cleaned-up using electrical contact cleaner, paper towels and Q-tips.
Once cleaned-up, lubricated and re-assembled, it now operates smoothly. Now I just need to decide if I'm going to use it or go with a more modern, "automatc" antenna...
https://www.classiczcars.com/forums/topic/30561-antenna-rework/
I guess it depends on weather you use the OEM radio or not. I am using the old AM/FM radio with the switch on the face. However I am using the modern antenna. to do this you need to rewire it to make it work manually. Personally I prefer this because I don't like the appearance of the antenna all the way up. I usually only extend it level with the roof . Because the OEM radio on a 240 isn't compatible with the automatic feature is another reason.
I have my original packed away with the original AM radio. The old Supertuner I have in the car has a power antenna lead, so I installed a modern automatic antenna to go with. If you are going to use a modern head unit, I'd probably use the modern antenna.
And if you ever find a source for more of those replacement masts for the original antenna, I'd love to have one.
I did the "37 year service" to my original antenna (and a couple of extras) and put it away for posterity. All of them went from barely moving and noisy as hell to smooth as glass and almost silent...almost a shame to file them away in a box! I am closing the fender, and installing a wire antenna in both the front and rear wind shield weatherstripping.
Arne,
I bought a replacement mast a few months ago from MSA and it worked fine. Almost identical to the original.
Michael
I purchased a metra 44-PW22 power antenna after reading another posting from Dave (zsondabrain) which I can not find right now. Does not look completely original but does the same job in my opinion and I can show you the look and style next time I am up your way. Or even take a photo tomorrow if you like.
This forum has ideas:
http://www.classiczcars.com/forums/showthread.php?t=31958&highlight=antenna
Arne,
Michael
Any chance you could post a picture of the tip of the mast?
