Posted January 29, 200520 yr comment_110603 Hello! I have a new problem today, namely a nut that won't come undone. The trouble is the bolt has been mangled and so the nut won't come off the end. Additionally, the bolt has been damaged and rotates pretty freely, so if I turn too hard the whole nut & bolt turns, instead of just the nut. I am happy to saw the entire thing off if that's my only option, as it is not essential. I don't know how though (not enough room for any kind of saw I know of). Please see the attached pics, can anyone help? :dead: Link to comment https://www.classiczcars.com/forums/topic/14804-removing-stuck-nut/ Share on other sites More sharing options...
January 29, 200520 yr comment_110604 I have had good results with a 3 inch dia. cut off wheel on a small die-grinder.Phred Link to comment https://www.classiczcars.com/forums/topic/14804-removing-stuck-nut/#findComment-110604 Share on other sites More sharing options...
January 29, 200520 yr comment_110642 Plenty of room for an angle grinder and cut off wheel like Phred said, If you don't have one nows the time/reason to get one, you'll use it a lot more once you have it, one handy item! Link to comment https://www.classiczcars.com/forums/topic/14804-removing-stuck-nut/#findComment-110642 Share on other sites More sharing options...
January 29, 200520 yr comment_110650 Lachlan, What about filing two flat sides onto the bolt then backing the nut back on. Then clean up the nasty end of the bolt bu either file or hacksaw (Removing the end of the bolt) And then undoing the nut straight off? I think I have a spare rear light panel somewhere, not sure if it's left or right. If you need to replace a mangled one. Link to comment https://www.classiczcars.com/forums/topic/14804-removing-stuck-nut/#findComment-110650 Share on other sites More sharing options...
January 29, 200520 yr comment_110654 A Dremmel tool with a cutting disk would work also. Link to comment https://www.classiczcars.com/forums/topic/14804-removing-stuck-nut/#findComment-110654 Share on other sites More sharing options...
January 29, 200520 yr Author comment_110663 Hey thanks for all the help guys! I ended up using a small blade from a hacksaw and got it off that way. Surprisingly didn't take too much effort anyway.Thanks for the offer Bruce, but it's not really mangled, just means one of the six bolts cant be used anymore :classic: Link to comment https://www.classiczcars.com/forums/topic/14804-removing-stuck-nut/#findComment-110663 Share on other sites More sharing options...
January 29, 200520 yr comment_110667 If you still can't get the nut out, Try pushing on her stomach or tickling her.......... Link to comment https://www.classiczcars.com/forums/topic/14804-removing-stuck-nut/#findComment-110667 Share on other sites More sharing options...
May 6, 201213 yr comment_389207 try to use nut splitter tool, or keep a thin water nozzle cooling the base and heat up by acetylene, simultaneously back and forth by a spanner. Link to comment https://www.classiczcars.com/forums/topic/14804-removing-stuck-nut/#findComment-389207 Share on other sites More sharing options...
May 6, 201213 yr comment_389210 ive taken 4 tail light garnishes off and 3 of them had threads that would spin. One i managed to get vice grips on thread and undo nut, subsequently stuffing the thread, and the other 2 i just used a grinder Link to comment https://www.classiczcars.com/forums/topic/14804-removing-stuck-nut/#findComment-389210 Share on other sites More sharing options...
May 6, 201213 yr comment_389248 On my first Z in 1977 I had a nut on a half shaft that was rusted on Back then I didn't know you guys and couldn't get good info that way. Not knowing any better I used a cold chisel and drove it into the side of the nut until there was a loud crack and it was loose. Link to comment https://www.classiczcars.com/forums/topic/14804-removing-stuck-nut/#findComment-389248 Share on other sites More sharing options...
May 11, 201213 yr comment_389674 I have had good results using vise grips like tez240k Link to comment https://www.classiczcars.com/forums/topic/14804-removing-stuck-nut/#findComment-389674 Share on other sites More sharing options...
May 12, 201213 yr comment_389786 even though you got the nut off you could still get an angle grinder. Link to comment https://www.classiczcars.com/forums/topic/14804-removing-stuck-nut/#findComment-389786 Share on other sites More sharing options...
