After a request as to where the 500 megs of Z car stuff went to. I upgraded the link to my new IP. After the change was made I checked to see if it was working, and it was. After a couple hours and a reply or two the entire thread just disappeared. So with out further adoo (Or something like that) here it is.
Over 800 megs of Z stuff
I tried to access this thread yesterday when I saw it on the main page. Said I didn't have privileges to access. Figured you had it under private discussion only.
Thanks for adding hosting again. A months or so ago I tried to access it finding to do avail. Figured you shut it down.
-Brandon
71 240Z
Brandon,
The IP is open to all and should work for you. I am not getting any error messages from the server software.
-Brandon
71 240Z
  • 10 months later...
Dave's ISP has moved several times since this data was originally made available back in 2002. If someone hasn't seen this stuff and wants to, perhaps an inquiry PM to Dave will clear things up as to whether it is still available. I don't see him listed as viewing the CZC site much these days.
