240z dash and steering column fitting - Help Me !! - Classic Z Car Club Skip to content
I'm stumped as to why my steering and dash aren't fitting correctly.
Series 1 240z
Original dash frame, replacement foam dash
Original steering column
Original steering column covers (I want to replace).
The main issue looks like the column covers are too far forward, there is a gap between where they mount around the ignition switch. Almost like the column is too long or the dash is too forward.
I would like the column to he pushed in.... But I'm assuming this this is permanently the same length.
There is no "casual reversible" telescoping function to the steering column.
It's designed to collapse or crush down some in length some in the event of an accident (think "accordion"), but no adjustments in length to make things fit better.
I'll take a look at how mine fits together when I get a chance. Yours might be as designed?
Looking at 240z i can see the plastic column covers that surround the ignition switch, turn signal and combiniation switch butts up against the dash. Its very strang as i feel like the dash should go forward about 1 inch.. but this makes it look like its needs to come back ~2 inches.
Almost seems like there is a 280z pedal box in there, with 240Z column and dash.
There is. The pedal box doesnt seem to effect the mounting position of the dashboard at all. I ended up drilling holes in box in order to properly mount the steering column however.
After thinking about it, the only explanation I can assume is when i glued the replacement foam onto the dash frame is thats its crooked somehow, even though all the contact points lined up. I think im just going to buy get a new set of plastic covers, which i need anyway, and extend them to cover the area. Then cover them with an automotive fabric or something. we will see.
I am pretty sure the 280Z dash and column cover are deeper than the 240Z dash and cover, even if they mount similar. You may even have a 240 dash on a 280 dash frame. Who knows at this point.
Sounds like you have your plan all set for new extended the covers and some fabric/glue to fix it up. Good luck. Just get it driving and enjoy the car!!!!
