Rough cold idle then smooths out - Page 12 - Fuel Injection - Classic Z Car Club Skip to content
13 minutes ago, Zed Head said:
I think that the original goal of your quest got diverted when a certain coil was chosen and discussed.
I went back to the basics of "replacing the coil on a 1978 280Z with an original specification coil" and then went to Rockauto. There are three choices there. The UF-4 is one of them. Might be where AI found it.
Only the Wells option shows actual primary circuit resistance though. It's the only confirmed choice. Good luck.
Interesting aside - says that they are epoxy-filled, not oil. Doesn't really matter, just interesting (to me anyway).
https://www.rockauto.com/en/catalog/nissan,1978,280z,2.8l+l6,1209260,ignition,ignition+coil,7060
Are all coils the same size? I ask because the standard motor parts one is the only coil that comes with it’s mount
The NGK coil came with a small half circle sleeve to take up the difference in diameter. Factory coils were fatter. Take a piece of rubber and attach it to the new coil to take up the difference
