Series 1 240z parts available - Parts Swapping - Classic Z Car Club Skip to content
I have a series 1, built 08/70, that is completely taken apart. I have basically everything off the car. If anyone is looking for parts please reach out and we can see if i have it available.
Located in Gilbert, AZ
  • 9 months later...
Here we are almost a year later..... if you still have parts, am looking for the early Series 1 shifter with the smaller horizontal pin and bushings, and a 0-140 psi temp/oil gauge. Thanks, John H. ntenna@me.com
Do you still have stuff? There are things I'd be interested in such as the tail light wire harnesses (both sides).
Allan,
I have a set of harnesses available, excellent condition.
Jim
Hello,
I did have a full wiring set from the 240z but i have no idea what the tail light harness looks like, and some stuff has been purchased. If you can get in touch with JFA.Series 1 i would suggest that.
im almost done with the 240z so everything else is available.
Hello,
I am using both shifter and oil.temp guage.
2 hours ago, jfa.series1 said:
Allan,
Jim
Is this the large plug version? I've got some of the smaller plug versions...the car has the larger plug on the body harness.
On 10/21/2026 at 6:14 PM, jfa.series1 said:
These look like small plugs. If you cannot get harnesses with the matching connectors, consider swapping them out to match the body harness. Vintage Connections can probably fix you up. https://www.vintageconnections.com/
Agreed, those do look like the smaller connection.
Keep the vin and vin tags, with the new china bodies, you will be able to sell it.
I restored the 240z, just didnt use some of the parts since i upgraded many of the components.
