I'm not much of a car person, so the resources I know of to reach out to are... low.
There's 2 Datsun 240Zs in my garage and, while neither run, one is a bit closer than the other. Figured I'd use one as an example for the other, in case I took something apart and didn't remember how to put it back together. Though, one has a part that I'm having trouble naming and it's not there on every image I've seen for the car online.
https://www.classiczcars.com/forums/topic/69699-whats-this-part/
The York compressor is very heavy and as @siteunseen mentioned, the compressor mounting bracket makes it very difficult to change the fuel pump. I had the same set-up installed on my '71 a few months after buying it. But, year later, removed it all and replaced with a modern rotary compressor and mount. I still have my York installation instructions and compressor mounting bracket on a shelf.
